92 Accord: Oil in spark plugs - Honda-Tech
Old 03-30-2008, 11:11 AM   #1
smetzger's Avatar
Default 92 Accord: Oil in spark plugs
Hi,
I have oil in my spark plugs.
About 4000 miles ago I was getting oil in the spark plugs, so I had the valve seals replaced.
What could be causing the valve seals to go bad (other than adding too much oil)?
Thanks,
Scott
smetzger is offline   Reply With Quote
Old 03-30-2008, 06:43 PM   #2
hmbtjc29's Avatar
Default Re: 92 Accord: Oil in spark plugs (smetzger)
What exactly is meant by oil IN your spark plugs? I assume by the post you mean on the combustion chamber side and not in the spark plug tube where the wire goes....if that's the case then obviously you need a VC gasket, etc. There are more things than just valve seals that can allow oil into the combustion chamber. It could be going past the rings or it could also be a bad PCV valve. How much oil is it using? Is it smoking at all?
hmbtjc29 is offline   Reply With Quote
Old 03-30-2008, 06:47 PM   #3
fleetw00d's Avatar
Just to be sure, do you mean oil ON the spark plugs (the part that goes in the cylinder) or oil IN the spark plug holes (where the plug wires attach)?
If it is the former, it could be the valve seals or oil leaking past the piston rings.
If the latter, there are two places the oil can get into the spark plug holes. If you're lucky, it is the four seals aournd the spark plug holes in the valve cover. A valve cover gasket kit should include the gasket, four o-rings for the plug holes, and grommet/wahsers for the valve cover nuts. If that doesn't fix it, then the o-rings under the rocker supports need to be replaced, this is more involved than the valve cover gasket.. You should be able to find instructions for both if you search this site.
Modified by fleetw00d at 9:54 PM 3/30/2008
fleetw00d is offline   Reply With Quote
Old 03-31-2008, 11:10 AM   #4
smetzger's Avatar
Default Re: 92 Accord: Oil in spark plugs (fleetw00d)
Its oil where the plug wires attach.
A valve cover gasket kit was installed 4000 miles ago. Not sure if the o-rings were replaced, I believe they were.
Thanks,
Scott
Old 03-31-2008, 11:15 AM   #5
H-T Order of Merit
TouringAccord's Avatar
don't just assume, make sure if they were or not.
Also, remember that there are upper tube seals and lower o-rings that seal oil from getting into the spark plug tubes.
TouringAccord is offline   Reply With Quote
oil on spark plugs scott757 Tech / Misc 7 09-09-2013 01:11 AM
1996 Accord. Oil filled spark plugs - seals replaced preludebro Honda Accord (1990 - 2002) 20 05-01-2011 10:39 AM
Oil in the spark plug tube, just changed valve cover seal jose310 Honda Accord (1990 - 2002) 13 01-12-2009 02:38 PM
Went to change spark plugs.....covered in oil...??? LAO Honda Accord (1990 - 2002) 7 12-19-2007 09:55 AM
Valve Tap/ Valve Cover gasket Replacment f22... standbackimapro Honda Accord (1990 - 2002) 5 04-29-2006 06:38 PM
Tags
1992, 92, 93, accord, bad, chamber, combustion, hondatech, oil, pcv, plug, plugs, seals, spark, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
