92 Accord Oil leak by Oil filter - Honda-Tech
Old 05-10-2005, 06:45 PM   #1
robertm2's Avatar
Default 92 Accord Oil leak by Oil filter
I just bought a 92 Honda Accord and besides the Taillights not working it has a bad oil leak coming from the Oil Filter area while running, is there some plug or anything that might be worn out near this area? I've removed the Oil filter and it has a nut in the center witch seams to remove this offset shaft that might be the problem but need better advice. thanks
Rob
robertm2 is offline   Reply With Quote
Old 05-10-2005, 08:33 PM   #2
hondadude's Avatar
Default Re: 92 Accord Oil leak by Oil filter (robertm2)
EX,LX, or DX??? Some have intercoolers between the block and filter that have a big 'O'ring under them, and the oil pressure sending unit [known leaker] is directly above the oil filter.
hondadude is offline   Reply With Quote
Old 05-11-2005, 10:33 AM   #3
robertm2's Avatar
Default Re: 92 Accord Oil leak by Oil filter (hondadude)
Itís an EX model, It might very well be that Oil cooler deal since that the only place I can see flowing from. Just in case, are both items fairly simple to remove and replace? Thanks
Old 05-12-2005, 05:53 PM   #4
robertm2's Avatar
Cool, It was the oil cooler seal....awesome deal for $400! Now all i need it to fix the running lights. Thanks for the help.
1995 v6 Accord Oil leak between oil filter base and oil pump glennt1959 Honda Accord (1990 - 2002) 6 01-14-2015 06:10 PM
2000 Accord V6 Oil Pan Removal RTTully Honda Accord (1990 - 2002) 1 11-11-2013 10:02 AM
94 accord Oil and coolant leak same spot dj00140 Honda Accord (1990 - 2002) 15 04-06-2010 10:41 AM
Oil leak from oil filter area '93 Accord 864dr1.3lcarb Honda Accord (1990 - 2002) 7 02-28-2009 08:31 PM
o-ring behind oil filter Origin Honda Accord (1990 - 2002) 3 04-15-2005 07:46 PM
Tags
2005, 90, 92, accord, area, bad, cooler, fileter, filter, honda, housing, leak, leaking, oil, seal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
