92 Accord LX 5-spd Not Turning Over But Can Jump Starter
All of a sudden (after jacking up to change a flat tire) the car will NOT start. When turning key to "START" you do get relays to click under the dash just below coin tray (starter relay ?) and then on the lower left kick panel fuse / relay holder...
All fuses check good. If I jumper +12V to the starter terminal / blade tab, the car will start and run fine. Can the relays be clicking and not be closing the contacts of the starter circuit ?
Re: 92 Accord LX 5-spd Not Turning Over But Can Jump Starter
I tried that and 0 Volts. There is more than one clicking relay under the dash. I can feel them. And fuses check OK. Stumped. Unless a relay is clicking and not making the 12V contact connection.
Try jumping the relay. Use a paper clip and put each end into the terminals on the connector where the switch is and try starting it. If that works then the relay is shot.
JDM_d15b_eg8
10-11-2007 03:55 PM
Junkyard2000
07-04-2005 10:55 PM
wambus
02-12-2004 03:09 PM
