'92 Accord EX fluid leak from the rear? - Honda-Tech
Old 11-30-2008, 09:05 PM   #1
Default '92 Accord EX fluid leak from the rear?
I was making a quick trip today when someone drove up next to me telling me I was leaking gas. I pulled over to check, and there was indeed a good amount of liquid leaking out of the bottom of the car right below the trunk. I did a sniff test on the liquid, but it wasn't gas. It smelled like slightly mildewy water, which would make sense if some rainwater pooled there since we just had a rainstorm the other day. I don't think it was coolant, but I've never known my car to collect rainwater like that before. I even checked my coolant levels, which were normal. It seems like it only leaks out when the engine is running.
I think I'm worried over nothing, but can anyone confirm my suspicion that it's just rainwater and not something else?
ChemBot is offline   Reply With Quote
Old 11-30-2008, 09:14 PM   #2
P_Adams's Avatar
You have nothing in the rear of the vehicle which would leak anything else but gasoline.
More than likely you've got either a leaking Trunk Seal, a leaking Tail Lamp assembly or a leaking Rear Window.
If you pull up the spare tire cover, you may find your reservoir; in the spare tire well.
P
P_Adams is offline   Reply With Quote
Old 11-30-2008, 10:27 PM   #3
Oh, yeah that makes sense. Thanks for the input! Although, I still worry that I may be leaking blinker fluid. I hear that stuff can get expensive...
Old 12-01-2008, 03:58 AM   #4
There is brake fluid in the rear, but you didn't mention anything about not being able to stop. So that's not your problem. Probably just water.
91EX4dr is offline   Reply With Quote
Old 12-01-2008, 05:43 AM   #5
P_Adams's Avatar
Have you changed over to Winter Air for the tires yet? Summer Air can leak over time (it's thinner) :-)
P
'92 Civic VX: rainwater entering hatchback area brians356 Honda Civic / Del Sol (1992 - 2000) 1 10-28-2016 10:35 AM
Honda Civic 95 Stock Radio/Stereo Removal BeanieHat Audio / Security / Video 21 02-09-2015 12:26 PM
Rain in Speed Sensor? pinks11 Honda Civic / Del Sol (1992 - 2000) 4 12-30-2008 06:38 PM
Light rain/water Ricey McRicerton Honda S2000 70 11-07-2007 05:55 PM
Trunk Weatherstripping?! tkosmith Honda Civic / Del Sol (1992 - 2000) 1 05-17-2005 05:42 PM
Tags
92, accord, acura, black, gas, honda, leacking, leaking, liquid, middle, oddessy, rear, smells, stuff, trunk
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
