91 Accord Transmission Problem
Old 03-29-2012, 09:46 PM
invader_zim's Avatar
Default 91 Accord Transmission Problem
I start the car and put it in reverse and its fine, but when I put it in drive and start to move it starts to run fine for a couple inches then starts slipping and the "s" light blinks until i turn the car off again. I was hoping it might just be the solenoid or the trans computer but something tells me the trans is done. Any input is appreciated
Old 03-29-2012, 10:23 PM
MM Gruppe B
MAD_MIKE's Avatar
Default Re: 91 Accord Transmission Problem
Pull out blue connector find out what code is. Click on H4A link in my sig.
Old 03-29-2012, 10:50 PM
Thank you, I checked the codes and got code 1, 2 & 8. Im guessing that my shift solenoid needs cleaning? Going to go clean it and report back
Old 03-29-2012, 11:07 PM
MM Gruppe B
MAD_MIKE's Avatar
Keep in mind, if you looked over that link, that some 90-91 TCUs had bad capacitors/resistors. Before you pull solenoids out, carefully remove the TCU and inspect its capacitors and resistors.
Old 03-30-2012, 10:05 AM
took out the tcu and inspected it, everything looks fine as far as that goes. going to be taking off the shift solenoid and cleaning it in a few minutes
Old 03-30-2012, 03:36 PM
Both solenoid assemblies have been cleaned and the only code now is code 8
Old 03-31-2012, 12:51 AM
MM Gruppe B
MAD_MIKE's Avatar
Did you check the resistance values of the solenoids coils? Check the connectors to them and your ground, should be on the front right corner on a metal bracket near the AT dipstick tube. Follow it directly from the negative battery cable.
Old 03-31-2012, 06:31 PM
Problem solved, it ended up being the sift solenoid. Replaced it andif shifts smoother than it did before. Thank you for your time and help!
dixiechevy01
07-05-2013 03:25 PM
Ray323
04-20-2013 11:37 AM
toasterblt
04-17-2012 12:45 AM
91POSAccord
03-12-2007 06:54 PM
12345
03-03-2004 12:44 PM
Quick Reply: 91 Accord Transmission Problem
