91 Accord just stopped running - Honda-Tech
Old 01-25-2013, 07:02 PM   #1
invader_zim's Avatar
Default 91 Accord just stopped running
91 Accord Wagon
Just recently replaced engine myslef (past couple days) and I have done engine swaps before with no problems
Has been running fine, no knocking, pinging, or other problems. More than 200 miles on it
So long story short I was driving home and i heard a sound that kinda sounded like a belt snapping then the car died. I noticed the battery light on. I pull over and the car just turns over, occasionally sounds like it wants to start but never does. There is a smell around the start/distributor area that smells like something electrical is fouling up. tested the coil and there is spark coming from it. I couldnt test much else because of the time. I need to figure out what might be wrong and things to check and how to check them. The car is not at my house and not even close to it. Any help is greatly appreciated.
Brian
invader_zim is offline   Reply With Quote
Old 01-25-2013, 07:32 PM   #2
SlowDA9teg's Avatar
Default Re: 91 Accord just stopped running
Might be the ignition control module?
SlowDA9teg is offline   Reply With Quote
Old 01-25-2013, 10:20 PM   #3
10thcb7's Avatar
Quote:
thats usually the first thing every 1 should check
try to see if the cam rotates when you crank it
btw there are two diff icm so i dont know if maybe during the swap the wrong distributor was used
10thcb7 is offline   Reply With Quote
Old 01-26-2013, 10:19 AM   #4
I am going to check the ICM today, I am also bringing a spare main relay.
Yes the cam rotates, it has new timing belt, tensioners, balance shaft belt etc.
The distributor that is on there is 100% most definitely the distributor that was on my old engine. I am hoping it is just something simple like the ICM or Main Relay.
GSR starter wierd during compression test guyver13 Acura Integra 3 05-27-2015 01:15 PM
Engine Compartment VIN Center-Punch for Recall pacdecimal Honda Accord (1990 - 2002) 1 07-04-2014 06:34 AM
gsr won't go pass 3600 rpm dc2much Acura Integra 7 03-17-2010 08:19 PM
Smells like gas & CEL on Sir Ash Honda Civic / Del Sol (1992 - 2000) 19 09-07-2009 05:42 PM
H23Vtec need your help please! RJonathan Honda Prelude 5 12-25-2005 09:46 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
