91 Accord F22A1 Ignition Timing - Honda-Tech
Old 12-31-2011, 11:45 AM   #1
Default 91 Accord F22A1 Ignition Timing
I am trying to set the Ignition timing on a 91 F22A1. Looks simple enough except when I open the plug the pointer is there but there are not any timing marks on the flywheel. On the front of the engine, pulley end, there is not a pointer or any grooves cut in the pulleys.
What am I missing?
gacinaz is offline   Reply With Quote
Old 12-31-2011, 12:09 PM   #2
Default Re: 91 Accord F22A1 Ignition Timing
It's on the flywheel. Sometimes if the flywheel is rusted the marks are harder to see. You can turn the wheels all the way to the left and get a wrench on the crank pulley bolt and with the tranmission in neutral you can have someone turn the bolt COUNTERCLOCKWISE until you can see the marks. Then use a black sharpie to make marks on the flywheel so you can see them better with the timing light on it.
holmesnmanny is online now   Reply With Quote
Old 12-31-2011, 02:02 PM   #3
Am I correct that when cylinder number 1 is at the top of it's stroke I am either at TDC or 180 degree off TDC?
Old 12-31-2011, 03:02 PM   #4
Ok, I turned the wheels out and turned the crank pulley nut CLOCKWISE and watched the flywheel. Still no marks. I took out the number 1 spark plug and watched as the piston started coming up. I turned very slowly and watched with a flashlight still no marks so I brought the number 1 cylinder around to the next iteration and did the same thing but still nothing. I took a rag and some brake cleaner and cleaned the flywheel surface to a clean silver color and tried again. Still nothing.
My Haynes manual shows a fairly noticeable mark and I don't even have a scratch.
Help.
Old 12-31-2011, 04:26 PM   #5
It's there it's just kinda hard to see. It's more of a slight scratch than a clear mark. There will be two sets. You will want the set with more marks. It will have -15 degrees and one mark ahead and one mark behind it, like I said, more of a scratch. And remember, they are not on the teeth, they are to the right of it.
Old 01-01-2012, 08:04 AM   #6
Ok, I checked again and there just are not any marks. I am wondering if some changed the flywheel and used one that was not marked.
Is there any way to mark the flywheel short of replacing it? Does anyone have pictures of a flywheel with the marks that I can use to mark mine closest enough to get through emissions?
d15b7 cam timing marks black0hatch Honda Civic / Del Sol (1992 - 2000) 2 08-27-2009 06:54 PM
help on timing on a 96 civic Civic-Kids Honda Civic / Del Sol (1992 - 2000) 25 04-29-2009 08:37 PM
Reinstalling Head tips and pointers also Rear Balance Shaft Question SrT4u2nV Honda Prelude 7 05-16-2006 03:43 PM
H22a timing EsQueue Honda Prelude 5 01-14-2004 03:36 PM
TDC pointer? Soled Out Tech / Misc 1 01-14-2003 11:09 AM
Tags
1991, 91, 91honda, accord, accordf22a1, check, dx, f22a1, howvto, location, marks, number, piston, set, setting, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
