91 Accord engine Replacement - Honda-Tech
Old 10-11-2009, 04:15 AM   #1
Default 91 Accord engine Replacement
I am doing an engine replacement, its my 1st time doing this and want to find as much resources as possible before i go a head with removing and installing. Just about the only information i can tell you is that i will be swaping out/in a stock lx engine i believe its f22a1. Can someone please direct me to a complete outline of engine removal and installation as well as a possible cheaper engine that i could put in, its my DD so i want it to be as efficient as possible, thanks.
.inbou is offline   Reply With Quote
Old 10-11-2009, 07:25 AM   #2
night's Avatar
Default Re: 91 Accord engine Replacement
there is no cheaper engine than that one
night is offline   Reply With Quote
Old 10-11-2009, 07:32 AM   #3
F22x engines are a dime a dozen so you are not going to get cheaper than that.........
YeuEmMaiMai is offline   Reply With Quote
Old 10-13-2009, 11:57 AM   #4
P_Adams's Avatar
Quote:
There should be a reference in the FAQ section for online Honda Shop Manuals which will guide you through your project.
For simplicity's sake (and that of you wallet as well) stay with the stock engine.
If, after this project you're still smiling and haven't fallen into a life of deprivation and alcohol THEN you can entertain getting fancy
P
P_Adams is offline   Reply With Quote
Old 10-13-2009, 06:03 PM   #5
MagnaniEG6's Avatar
Best forum for this is CB7tuner.com all info on 1990-1993. But for cheap F22B about what $600-800
MagnaniEG6 is offline   Reply With Quote
Old 10-13-2009, 06:26 PM   #6
Quote:
thanks for the site, its already helping me out.
Old 10-15-2009, 03:38 PM   #7
P
just found the article in the faq section, its good stuff.
Old 10-16-2009, 07:16 AM   #8
EKw94JDMGSR's Avatar
I have a 91 accord EX F22A4 engine with a H23 Intake Manifold, Bisimoto Intake Manifold gasket, Ebay headers w/ Paceheader plage welded on, new Bisimoto head gasket not installed, new felpro oil pan gasket not installed, new plugs, wires, cap, rotor, new thermostat, and engine has never been over heated. Let it go very cheap with all items mentioned above. Its a USDM original Miles 315,xxx, does not smoke, or knock, still running strong. I have some pics on CB7tuner > thread: out w/ F22A4 in w/ H22A. Let me know if interested I will let the complete engine go for $300.00 includes ECU, EWH, all sensors, no motor mounts.
EKw94JDMGSR is offline   Reply With Quote
Old 10-16-2009, 02:49 PM   #9
ill pass
Old 10-16-2009, 04:21 PM   #10
nus_dogg's Avatar
I say stay with the F22A since you just want it stock and as efficient as possible. Get a F22A6 which is the best F22A you'll find.
nus_dogg is offline   Reply With Quote
Old 10-17-2009, 04:25 PM   #11
Quote:
whats the difference compared to the other f22ax
Old 10-17-2009, 11:17 PM   #12
nus_dogg's Avatar
Alot of ppl said the F22A6 head flows the best out of all F22Ax motors and pulls stronger than the rest as well. So I think it'll be a good reliable motor for you and your car.
Can an EF be rolled in the shop with no front crossmember? Vagitarian Honda CRX / EF Civic (1988 - 1991) 17 05-04-2012 10:36 AM
Is it possible to remove pistons without removing engine block on a H23A1? iponnet Honda Prelude 2 03-14-2011 04:57 AM
4th Generation Wagon Rear Wiper Blade Replacement fleetw00d Honda Accord (1990 - 2002) 4 12-02-2009 07:26 PM
Removing/installing Engine without Hoist vinuneuro Honda Prelude 11 05-15-2007 09:24 AM
Tranny Removal and Install integraGSR213 Acura Integra 8 02-09-2004 04:16 PM
Tags
1990, 1993, 90, 91, accord, custom, engine, engines, f22a1, guide, honda, motor, removal, replacement, stock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
