83 Honda Accord Cold Running Problem
Old 10-29-2006, 10:31 AM
sks3266's Avatar
Default 83 Honda Accord Cold Running Problem
Car always starts up fine, and if it's WARM outside, I can hardly tell there is a problem.
BUT... When it's COLD outside, it will start right up, but begins to cut out and miss - spits & sputters. The colder the temp, the worse this is.
Then, when engine reaches operating temp, it runs fine, and will continue to run fine all day. It acts like an ignitor problem break down. I have replaced plugs & wires and distributor cap & rotor. Have even added manual choke cable, but nothing helps during cold weather.
Would appreciate any help/suggestions. Thx.
Old 10-29-2006, 12:00 PM
In a Junkyard near you.
Ross 2.0's Avatar
is the cold air valve working on the intake?
bitter rod
21
08-18-2010 12:13 AM
chrisfromsrq
07-21-2009 08:41 AM
Quick Reply: 83 Honda Accord Cold Running Problem
