82 Accord EK1 Head Bolt Torque
I am doing a rebuild of the cylinder head on my 82 Accord, the head gasket developed a leak from the previous owner (over heat) and the #2 cylinder had a coolant leak. It definately needs a rebuild, with new valve seals, but my question is on torque.
After a bit of searching, I came across a final torque setting of 49 ft lbs, torquing all bolts in pattern to 15 ft lbs, then go in 5 lb increments in the same pattern order until reaching 49 ft lbs.
Does this sound correct? I don't have a shop manual (local parts stores don't go back that far) and I really don't need one otherwise. 49 ft lbs sounds awfully low, but hey, it's a 4 cylinder.
Thanks in advance!
Thanks in advance!
BoostedSi
04-13-2024 11:29 PM
SlammedDC2teg
12-26-2011 06:50 PM
LDTFbsst
03-16-2010 06:13 AM
