6th gen Accord 5th gen front end? ? ?
Old 05-14-2015, 02:42 AM
sepetinswenze's Avatar
Default 6th gen Accord 5th gen front end? ? ?
Hi guys, i did a bit of searching but couldnt find much about if its fairly reasonable to swap a 5th gen front end onto a 6th gen accord? ? Thanks.
Old 05-14-2015, 07:38 AM
He knows where you live!
TheMuffinMan's Avatar
Default Re: 6th gen Accord 5th gen front end? ? ?
Buy a 5th Gen Accord.
Old 05-14-2015, 06:02 PM
Agh man cant believe I didn't think of that. Thanks for the help!
Old 05-14-2015, 07:30 PM
The vehicles are entirely different in shape for the front end. You're not asking if a coupe bumper fits a sedan from the same generation.
I'm sure you can slap on some bondo and make it look ok but it's not anything close to what you'd call "fairly easy". I'd treat it more like the California Type-R headlight swap from back in the day.
Right off the bat:
- Hoods are different
- Headlights are different (fender where it meets headlight is different)
- Grill is integrated into bumper cover
- different shaped bumper obviously
So if "fairly reasonable" means buying or modifying your hood, fenders, grill, radiator support, etc then absolutely it's fairly reasonable.
I consider "fairly reasonable" to be doing the coupe/sedan bumper swap where you aren't doing nearly as much work and everything lines up as it should.
xmrxnguy3nx
08-06-2009 05:23 PM
SkimN
04-10-2007 09:18 PM
goku21
06-29-2004 09:36 PM
JDEM1
12-17-2003 10:07 PM
Quick Reply: 6th gen Accord 5th gen front end? ? ?
