4th Generation Wagon Rear Wiper Blade Replacement
Old 12-01-2009, 08:55 AM
fleetw00d's Avatar
Default 4th Generation Wagon Rear Wiper Blade Replacement
My daughter (in FL) has a 93 LX Wagon on which she needs/wants to replace the rear wiper blade. She and a engineering friend can't figure out how to remove/replace the blade (not a good sign for an engineering major) from the arm. She claims it is not a J hook arrangement like the front blades (she managed to replace those). The Honda service manual doesn't provide specifics for removal/replacement and I haven't found a wagon locally (OH) to look at myself (I found a 94, but is has a J hook).
If anyone can provide a description of how to do this, I (and my daughter) would appreciate it. She doesn't want to wait until she is home for Christmas.
Old 12-01-2009, 09:49 AM
bigsnorlax's Avatar
Default Re: 4th Generation Wagon Rear Wiper Blade Replacement
Not sure if this helps.. just found it online and thought it was worth showing
Old 12-01-2009, 02:39 PM
redbull-1's Avatar
If it is not the J-hook type, it might be the pin-arm type. She might have to pry a clip off first, then pull the blade out of the arm.
http://www.silblade.com/installation/index.cfm
Old 12-01-2009, 03:16 PM
fleetw00d's Avatar
I saw that picture on Majestic Honda's site; should have used my reading glasses. It does look like a pin sticking out the side of the blade with a small "L" bracket behind it. Any wagon owners know if there is a clip or whether the pin just "snaps" into the arm?
Old 12-02-2009, 06:26 PM
fleetw00d's Avatar
They figured it out.
Old 05-21-2018, 09:43 AM
Anna Henton's Avatar
I got pissed with the side pin setup on my 91 wagon so I replaced the entire arm with a J hook arm from a 99 CR-V. No more frustrating side pin. Next time I go to the junkyard I'll replace it with a longer arm, but for now, it works great.
Option
02-10-2004 10:34 AM
iwantfastcars
04-04-2003 10:25 AM
Mikes94
07-11-2001 10:49 PM
Quick Reply: 4th Generation Wagon Rear Wiper Blade Replacement
