4 lug to 5 lug conversion
Old 04-17-2013, 08:22 AM
95accord-R's Avatar
Icon2 4 lug to 5 lug conversion
Can i take a V6 accords 5 lug hub and put it on my 2001 accord which has 4 lug?
Old 04-17-2013, 08:38 AM
95accord-R's Avatar
Default Re: 4 lug to 5 lug conversion
i have all the suspension, steering, and brakes parts from the accord V6
Old 04-17-2013, 09:15 AM
Fitz Williams's Avatar
I know the rear's are the same. Honda lists the same part number for the front knuckles. It should work.
Old 04-17-2013, 09:57 AM
ncoutlaw's Avatar
Yes you can
Old 04-18-2013, 08:21 AM
95accord-R's Avatar
ok thanks guys
Old 04-19-2013, 07:53 AM
95accord-R's Avatar
what about the driveshafts are they the same
Old 04-19-2013, 06:35 PM
Nathan007's Avatar
I just did the conversion last week, and assuming you already have rear disk brakes, it's fairly simple.
You will need:
rear v6 hub bearing assy, rear disks (may reuse calipers and pads)
front v6 hub, new bearings, v6 calipers, v6 discs and pads(bigger than 4cyl)
Dorman makes fairly priced hubs it's what i used.
do a search, there's a few DIY about it.
axles will fit without issues btw
Old 04-22-2013, 08:19 AM
95accord-R's Avatar
ok thanks
Old 12-19-2018, 12:48 PM
Camilo Mejia's Avatar
[QUOTE=Nathan007;48699281]I just did the conversion last week, and assuming you already have rear disk brakes, it's fairly simple.
You will need:
axles will fit without issues.
i know this thread is old but its worth a try can the same be done with a 99 accord lx 2.3l? Just switch hubs on front and change rear knuckles to a disk n 5 lug???
Old 12-21-2018, 03:26 PM
schreps's Avatar
If it works on a 2001 it will work on a 1999. All the same suspension.
Old 12-26-2018, 10:45 AM
92eglsvtecutah's Avatar
it should work
tysonlifemv
06-11-2009 08:57 PM
Kr4nG
10-28-2008 08:42 AM
Dcsports92
02-27-2008 05:20 PM
WagOvan Man
02-28-2006 02:00 PM
campbuds
08-07-2004 08:25 AM
Quick Reply: 4 lug to 5 lug conversion
