2k accord crankshaft position sensor location
Is yours showing up as disconnected too? Its under the lower timing belt cover, pickup a haynes for pictures. My 98 accord has the same problem and somtimes just won't even start, major wtf. 100k on mine and this happens, time bomb, anybody know of a fix?
Re: (Patman)
my odbiII showed up a code for my crankshaft position sensor so i am trying to find it so i can change it out. my car is at a little over 100k. thanks for the post.
Re: (Patman)
CKP/TDC Sensors Replacement
Remove the balancer belt.
Remove the balancer belt drive pulley.
Disconnect the CKP/TDC sensors connector (A), then remove the CKP/TDC sensors (B).
Install the CKP/TDC sensors in reverse order of removal.
Install the balancer belt.
I'm thinking mine might be from moisture or maybe even oil come to think of it, I have been loosing some, about 1/4 quart every 1000 i think its getting worse, maybe its leaking out the side there and running all over the wiring?
MacMade
09-14-2020 12:09 PM
RWSStudios
Engine Management and Tuning
04-06-2014 12:08 PM
partialresponse
05-20-2010 02:08 PM
