2002 Honda Accord hard shifting - Honda-Tech
Old 05-07-2009, 05:12 AM   #1
New User
Default 2002 Honda Accord hard shifting
Hi,
Yes, I've read the other threads but my problem is slightly different. My Maint req light is on. When I put it in D4 it jerks. Only on 1st gear does it have like a grinding sound and stalls a bit then goes. When I slow down to first gear same problem. I haven't checked the fluid levels yet. Anything. I told someone about it and they said that it's not the transmission going out but maybe a part that needs to be fixed.
HondaSalsero is offline   Reply With Quote
Old 05-07-2009, 06:06 PM   #2
Default Re: 2002 Honda Accord hard shifting
Hey man your problem is your alternator...I had the same problem & my alternator went cuz I had a brand NEW High Performance Battery installed rescentlly & well it turned out to be the Alternator...Get it replaced ASAP unless you have AAA to get U outa a jam...later man Oh quick question you wouldn't to happen to know where I can get me some NICEE factory style foglights....that either already come in H.I.D's or ones I can put H.I.D's on them...Cuz right now I have TYC Projector Headlights with 8000K H.I.D's installed...So yea man lemme know thnx...
-Adrian-
Adrian525 is offline   Reply With Quote
Old 05-07-2009, 09:49 PM   #3
bseriescrxsi's Avatar
wtf are you talking about the alternator.....it makes no sense what so ever....your maintenance required light is only an oil change indicator and is tripped by mileage .....something may be wrong internall with the transmission
bseriescrxsi is offline   Reply With Quote
Old 05-07-2009, 09:58 PM   #4
that would be incorrect...cuz when I came outa D1 it stalled everythin turned off then right bak on...then the lights came on and wouldn't turn off....then the car jus died....
Old 05-08-2009, 03:42 AM   #5
Call me crazy but I don't think a bad alternator would cause his car to jerk when he puts it in gear. How many miles?
Leadberry is offline   Reply With Quote
Old 05-08-2009, 11:35 AM   #6
New User
It has 95,000 miles. I took it to this place and they told me that the 1st and 2nd gear clutch are going out. That they need to rebuild the transmission. 1500,00. Is there anything to keep it going longer? Maybe a tranny oil change?
Old 05-08-2009, 08:59 PM   #7
some people say if you don't change your trans fluid every 30k miles then don't do it.. something about the seals get used to the fluid thats in there lol idk if i believe it or not
notAdiesel is offline   Reply With Quote
Old 05-11-2009, 10:58 PM   #8
Quote:
then stop driving your car likes its a stick...but an alternator would not cause the car to jerk dude sry you must have had other issues....and as for the tranny....they say its not good to change the fluid that oftem because of the planetaries inside as the hondas dont have a changeable tranny filter
Popping of out 6th Gear Memo6453 Honda S2000 0 03-01-2010 02:53 PM
Tranny problems? ej1252 Tech / Misc 6 09-18-2008 10:23 PM
ITR 2nd gear problem HONDA_TEG Acura Integra Type-R 13 11-04-2005 05:22 PM
Gear slipping with cbr600f4i dude100 Honda Motorcycles 7 10-01-2004 09:10 PM
Help: Car wont go in gear when cold?? oldskooljdm Honda Civic / Del Sol (1992 - 2000) 8 12-09-2003 10:30 AM
Tags
2001, 2002, 2005, accord, alternator, bad, hard, honda, jerk, jerking, shift, shifting, shifts, stop, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
