2002 honda accord clock light question.
I think my bulb went out on my 2002 honda accord v6. Does anybody know how to replace this bulb. My clock is still on but at night when I turn the lights on the clock doesn't light up. Do I have to take the whole ac cluster to reach the bulb. Any info. would be appreciated. thanks
Re: 2002 honda accord clock light question. (ajmj)
dealership sells the bulb or you can get one from ebay. all you got to do is to pull with a bit of force at the clock cluster and it should come off. then just replace the bulb and snap it back in place..
Yup.... the day i bought my car the bulb went out...i think its $2.54 at a dealership the install process is really easy just like sleeps2much said juse a screwdriver but be carefull not to scratch up the otuside plastic and then all you do is screw out the little bulb and screw in the new one...good luck
Re: 2002 honda accord clock light question. (dima)
Best thing to do is get a really small flathead and wrap it in electrical tape. That will prevent any scratching.
Re: 2002 honda accord clock light question. (H2290)
Step 4 on these instructions talk about removing the clock:
http://www.handa-accessories.c...d.pdf
Which, as mentioned above, involves a flathead wrapped in tape though I use masking tape, plus a strip of masking tape right under the clock (what the screwdriver is touching when you start prying on the bottom of the clock).
Re: 2002 honda accord clock light question. (Heat)
There's actually a service bulletin on the clock light bulbs going out prematurely on 98-02 Accords and Odysseys. There is an updated bulb and seperate part number.
Failed bulb p/n is 35505-584-N01 If this is the part you got, then take it back! They ARE still selling it believe it or not!
New p/n 33505-S84-B02
Bulletin# 01-097
Bulletin# 01-097
