2001 accord radiator fan not working
Old 06-03-2015, 01:26 PM
Honda kid 44's Avatar
Default 2001 accord radiator fan not working
Hello, does anyone know why my radiator fans wouldn't be working? I've tested the fan and it works, I tested the relays, that wasn't the problem. And I've also replaced the electric thermo switch on the lower radiator hose. What else is there and how can I fix it?
Thanks!
Old 06-03-2015, 02:23 PM
Lost Again's Avatar
Default Re: 2001 accord radiator fan not working
Four or six cyl engine.
Does the AC work.
What exaclty is going on.....car starts to overheat and the fans do not come on?
Old 06-03-2015, 07:18 PM
4 cylinder. A/C works. Fans will just NOT come on whatsoever.
Old 06-06-2015, 03:32 AM
Lost Again's Avatar
Don't take this wrong, I'm just want to be clear on what is going on.
You can put 12v directly to BOTH fans and they will run - Correct?
Engine running and you turn on the AC. AC compressor is running and cold air through vents but BOTH fans DO NOT run - Correct?
Old 06-13-2015, 06:19 AM
Yes, Exactly.
Old 06-13-2015, 07:13 AM
Lost Again's Avatar
Several fuses to check......
Under hood- #57 and #58 - 20 amp
Drivers under dash - #4 - 7.5 amp
naa10104
Honda CR-V & Element
05-17-2018 09:23 PM
longdistance
01-10-2016 11:10 AM
Powerboss
02-20-2014 11:39 AM
nirajorel
08-28-2012 12:30 PM
cn_bb
08-09-2012 11:00 AM
Quick Reply: 2001 accord radiator fan not working
