2001 Accord cranks but will not start, please help! - Honda-Tech
Old 01-28-2013, 10:58 AM   #1
Icon3 2001 Accord cranks but will not start, please help!
My 2001 Accord suddenly will not start. We are on vacation and supposed to be driving home today but can't find the problem. It cranks but never starts. I checked the fuel pump which seems to be working, and it has spark. I sprayed starter fluid in the intake and still won't start. I also tried resetting the computer on the off chance that the immobilizer was the problem but no luck. I have run out of ideas. Anyone have any suggestions?
kcollings is offline   Reply With Quote
Old 01-28-2013, 11:14 AM   #2
jdowen2's Avatar
Default Re: 2001 Accord cranks but will not start, please help!
Chek engine light on? If so, check for codes.
jdowen2 is offline   Reply With Quote
Old 01-28-2013, 11:40 AM   #3
SlowDA9teg's Avatar
Ignition control module inside your dizzy? Main relay?
SlowDA9teg is offline   Reply With Quote
Old 01-28-2013, 07:05 PM   #4
I tried all the basics (i.e. plugs, cap and rotor, wires) related to spark which leads me to think its a fuel issue. It seems like I have fuel pressure at least up to the fuel rail. How would I check the ignition control module?
Old 01-28-2013, 08:13 PM   #5
So I just noticed that my check engine light is not on when I'm cranking it. Help...
Old 01-28-2013, 09:44 PM   #6
Take one of your plugs out, put the plug wire back on and ground the bottom of the plug to the block or valve cover while someone turns the car over with the starter. You should see and hear the plug firing. If not you might have a bad coil.
f1drivr is offline   Reply With Quote
Old 01-28-2013, 09:50 PM   #7
Well I just got the obd codes, and they translate as follows: misfire, fuel, ccm, cad. conv., evap, o2, htr, egr. The guy that ran the test didn't give me the specific codes so thats what I have to work with. And I checked all the plug wires, they all are getting spark.
Old 01-29-2013, 03:59 AM   #8
Could it be the ignition control module? I followed the spark up to that point but haven't tested it yet.
Replaced Ecu in 2001 honda KeeshaunaG7 Honda Accord (1990 - 2002) 6 01-09-2017 04:11 AM
01 Accord EX Cranks but won't start Meyerwi Honda Accord (1990 - 2002) 12 12-24-2013 07:31 AM
Accord 2001 starting issues Scrapatak Honda Accord (1990 - 2002) 0 08-14-2013 11:19 AM
2001 honda accord wont start need help!!!!! Ak_JDM19 Honda Accord (1990 - 2002) 2 11-16-2011 06:54 AM
91 Accord SE sporatic no start but cranks problem HELP!!!!! nyjts2856 Honda Accord (1990 - 2002) 7 07-21-2005 06:38 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
