2001 accord Auto.... ?? why does my DASH brake light come on????
I have a 2001 honda accord with 96k on it.
Recently had all new pad, & rotors installed.
<FONT COLOR="green"> I notice that sometimes AFTER i start my car, the DASH brake like indicator is still on. I never use my ebrade since I have an auto.
Once I'm driving, sometimes it turns off & sometimes it stays on for the entire trip.
</FONT>
It does not affect any braking of the car... having the DASH brake light on just irriates me.
Charlie Neng Moua
</FONT>
Charlie Neng Moua
Re: 2001 accord Auto.... ?? why does my DASH brake light come on???? (Charlie Moua)
<FONT SIZE="5"> never mind.... i found a link to honda bulletins..</FONT>
http://www.98exl.com/tsb/CG/03...f.pdf
Re: 2001 accord Auto.... ?? why does my DASH brake light come on???? (thapimpfromchi)
hah LOL
Man I use to be really good at searching... but for the past 2yrs haven't spent much time on honda-tech at all much. Now I'm just lazy about looking for answers.. jk
Charlie Moua
Charlie Moua
Re: (ilikehonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilikehonda »</TD></TR><TR><TD CLASS="quote">i didnt know that accord dashes had brakes</TD></TR></TABLE>
No one said the Accord dash had brakes. However, they were talking about the brake light indicator on the dash. I really don't know if you were trying to be sarcastic, but...
check your brake fluid, when it goes below a certain level the light comes on. Also, if you just changed your brakes you should probably bleed them to get any air out.
Re: (philadd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philadd »</TD></TR><TR><TD CLASS="quote">
No one said the Accord dash had brakes. However, they were talking about the brake light indicator on the dash. I really don't know if you were trying to be sarcastic, but...</TD></TR></TABLE>
well he said his dash brake lights were on. yes it is a sarcastic statement
Re: (ilikehonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilikehonda »</TD></TR><TR><TD CLASS="quote">Well he said his dash brake lights were on.</TD></TR></TABLE>
No. He said his dash brake light indicator was on.
Re: (steadypimpin)
Time for Clarity?
The dashboard brake indicator can come on for several different reasons. A brake light could be out, your brake fluid could be low, the filter could be blocking venting, etc.
So top off the brake fluid, check your lights, and if there is still a problem change the filter.
So, did the TSB apply to your problem? Did it fix it?
just put electrical tape over the spot on the guage and keep on driving until you can't stop no more .. then change your brakes ..
It Wasn't Me!
1 Post
Re: (H2290)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H2290 »</TD></TR><TR><TD CLASS="quote">Time for Clarity?
So, did the TSB apply to your problem? Did it fix it?</TD></TR></TABLE>
This is the 98-02 cluster. The brake lamd indicator and the brake indicator are seperate lights. The brake indicator at the top of the cluster will not come on for a brake light out. It comes on for a fault in the system like low fluid or if the parking brake is on. The brake lamp indicator is at the bottom of the cluster below the car diagram which show open doors. It comes on for a bad bulb.
Most likely cause of the OP's problem is slightly low brake fluid or the float on the resevoir sticking. Float sticking is a pretty common problem on these cars.
What filter are you reccomending he change?
DeVus32v
07-31-2006 07:40 PM
