2000honda accord lx. Overheats and heater does not blow but ac does please help
I'm trying to fix my girls car it over heated on her again the first time it did we got the water pump changed and a few weeks later it over heated again so I changed a heater hose and thermostat. Now a few weeks later it over heated and I can't figure it out but now the heaterwont even blow but the ac does?? Anyone have any ideas?? I was kinda thinks the heater control valve??
Re: 2000honda accord lx. Overheats and heater does not blow but ac does please help
Are both fans running when it overheats ? Does the lower radiator hose get hot throughout the hose when it starts to overheat ?
Ok so i tried today messing with it i could not get it to over heat but both fans were turning on and off with the ac and at first the heater would not work.. but now it is?? I am so confused and thisis her only car and she is prego due next week we need this car yes the lower hose is hot threw the whole hose
It doesn't matter if the fans come on when the ac is turned on, you need to see if the fans come on when it starts to overheat when the ac is off.
But I think I fixed the over heating issue by flushing the coolant.
Issue fixed car is no longer over heating turns out i had water in the system but antifreeze works much better..
And the heater must be a different issue so thanks everyone
Aaron Cayabyab
36
06-14-2012 09:20 PM
skoolz4loserz
08-21-2007 07:43 PM
AlphaKennyWun
01-23-2002 05:24 PM
