2000 honda accord ex v6 missing
i have a 2000 honda accord ex v6 it is missing really bad i have change all plugs, coil packs, it throws codes p1399 which is manufactur ignition cntrl, p0301 cyl. 1 misfire, p0302 cyl. 2 misfire, p0303 cyl.3 misfire, p0305 cyl. 5 misfire, p0306 cyl. 6 misfire, p1300 multi cyl misfire all these codes and not fixed cant figure it out wtf i need help asap let me know what u guys think pm me or text me 218-393-4677 thanks Dave
Re: 2000 honda accord ex v6 missing
Do make sure with right size sparkplug and coil pack? If I read your story is you just mess up with ignition, double check again when you change all those stuff if you scared change one by one.
so tell me how you do it? if you get oe part from honda you shouldn't get problem if you just change the sparkplug and coil pack,may be your step is wrong or something can couse that problem.
so explain to me what this step is it really isnt hard to figure out how to unplug a coil pack, unbolt it and pulling it off the motor and taking out the spark plug
this is a pretty lame site no one is ever helpful and everytime i put a post i get negative responses and just ******** that think im retarded this is the worst forum i have ever been too
Yea the site can be a little crappy at times, but when they help, they HELP.
I guess the lack of responses is because most people here owns 4 cyl and therefore is used to the 4cyl systems.
Firing order? IDK (I'm sure you got it correct) Why don't you reset the ECU (remove and reinstall neg cable from battery) and try it again. Any not connected ground wires? Worst come to worst, put back your old coil packs.
if your getting random miss fore codes i would be looking at a data list to see what the fuel trims are like.
this sounds like tight valves.tight valves will cause a rough idle and set a random miss fire have it checked @ honda .
no it cant be a cat or egr so dont go changing it because some one said it was .
how many miles are on the car ?
Re: 2000 honda accord ex v6 missing- P Adams
There are a few gurus on this site who can answer all your questions step by step. Especially P Adams, who seems to have less frequent this site lately.
rwkgramps11
03-19-2023 12:44 PM
Silly rabbit419
03-17-2018 04:56 AM
