2000 honda accord code p0705
Old 06-09-2013, 12:20 PM
chriscar00's Avatar
Default 2000 honda accord code p0705
code p0705 came up and i tested all the solenoids and they checked out ok. When the car goes to shift the rpms jump up aprx 300-400 rpm. just seeing if anyone had any ideas thanks
Old 06-09-2013, 12:25 PM
MidasGuy's Avatar
Default Re: 2000 honda accord code p0705
P0705 Short in Transmission Range Switch Circuit (Multiple Shift-position Input)
Old 08-24-2013, 07:55 PM
dlangford's Avatar
I have a similar problem with a 99 accord automatic. The check engine light came on as well as the maintenance required light. Several error codes (P0705, P0706, P0420 & P0430). I've seen P0420 before, replaced oxygen sensor at exhaust manifold and it went away. I'm new to the forum and can't seem to find anything about the short in transmission range switch circuit error code. any help would be appreciated.
Old 08-25-2013, 05:46 AM
Lost Again's Avatar
Recheck the codes? I see a P1706 and P1706 for the trans range switch
Ali Hussain Ali
04-08-2014 07:48 PM
psphilip
09-09-2013 04:43 AM
joshua89
07-30-2011 01:36 PM
jwc104
11-17-2009 07:44 PM
Quick Reply: 2000 honda accord code p0705
