2000 Accord V6 Oil Pan Removal - Honda-Tech
Old 08-01-2004, 10:17 AM   #1
RTTully's Avatar
Default 2000 Accord V6 Oil Pan Removal
I need to know how to remove the oil pan on a 2000 Accord V6. It looks like it might come out by just removing the exhaust "Y" pipe first, but I want to know if there are any other problems before I get started.
The oil pan on my 2000 Accord V6 started leaking when I had the Timing Belts replaced.
That doesn't make a lot of sense to me, and the shop that replaced the Timing Belts told me that the oil pan is not touched during the timing belt and water pump work.
The oil pan is leaking at the corner next to the oil filter.
When I look at the "gasket" it does not look like it was created during factory assembly. It has peaks and gaps in it.
RTTully is offline   Reply With Quote
Old 11-11-2013, 10:02 AM   #2
Default Re: 2000 Accord V6 Oil Pan Removal
I need to know how to remove the oil pan from a 2000 Honda Accord. Is there anything real technical like having to pull the engine or anything like that or is it a relatively simple process. Please explain in detail.
milliemo is offline   Reply With Quote
Honda Accord Oil Pan Leak- Need Your Insight. nico08 Honda Accord & Crosstour (2003 - Current) 5 04-24-2016 02:15 AM
Hole in oil pan, but engine runs? EddieVonDub Honda Civic / Del Sol (1992 - 2000) 8 11-22-2014 05:36 PM
Oil pan removal - f23A1 - Oil pan/Exhaust experts j894 Honda Accord (1990 - 2002) 5 03-21-2014 03:11 PM
LS/VTEC Oil Pan Leak.. Too much pressure? Bad gasket? Warped pan? 92integraVTECgsr Acura Integra 13 03-10-2011 05:25 AM
oil leak, crankshaft seal. crxdriver89 Honda CRX / EF Civic (1988 - 1991) 3 03-13-2006 02:49 PM
Tags
04, 2000, 99, accord, change, honda, leak, leakaccord, located, oil, pan, problems, remove, replacement, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
