2000 accord v6 EGR port cleaning - Honda-Tech
Old 12-15-2012, 09:23 AM   #1
Default 2000 accord v6 EGR port cleaning
Have 2000 accord with 175k. Shop changed EGR valve twice and engine light comes on following 10 miles of driving. Heard so tech bulletin 99-085 to clean the EGR ports. Any tips on removing the intake manifold and cleaning ports? Any other routine maintenance I should perform while intake is off?
F16pilotjd is offline   Reply With Quote
Old 12-15-2012, 11:35 AM   #2
jdowen2's Avatar
Default Re: 2000 accord v6 EGR port cleaning
jdowen2 is offline   Reply With Quote
Old 12-17-2012, 06:33 PM   #3
Thanks. This should help.
Old 12-18-2012, 10:20 AM   #4
While I have the intake manifold off do you recommend any routine service? Can I get away with just cleaning the ports and not installing the $147 plastic tube?
Old 12-18-2012, 02:55 PM   #5
jdowen2's Avatar
Clean throttle body and IAC.
Old 12-19-2012, 03:45 PM   #6
Jdowen2,
This may seem a little basic, but just spray with carb cleaner? Any seals I need to be concerned with?
I am an old plane mechanic and pilot so this newer tech stuff is a challenge to do correctly for the layman.
Thanks
Old 12-19-2012, 05:01 PM   #7
jdowen2's Avatar
Need gasket for throttle body. Just spray with throttle body cleaner. I think carb cleaner is more corrosive but not sure.
ERG valve or EGR passage knaup109 Honda Accord (1990 - 2002) 13 03-02-2015 08:36 PM
1990 accord ex E.C.Smith76 Honda Accord (1990 - 2002) 3 12-07-2013 08:51 AM
1993 Honda ACCORD EGR mfernandez72490 Honda Accord (1990 - 2002) 3 03-06-2011 08:13 PM
F23a4 with CEL P401 - No EGR Plugs TheBigCheese Honda Accord (1990 - 2002) 2 02-03-2011 12:33 PM
code 12 egr petercampusa1 Honda Accord (1990 - 2002) 1 12-11-2008 11:10 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
