2000 Accord ulev vtec, vtec malfunction code P1259
Old 01-27-2012, 11:30 AM
dwr1977's Avatar
Default 2000 Accord ulev vtec, vtec malfunction code P1259
I have just pulled the head and replaced 2 burnt valves. I had the head machined a cleand up and now have the 1259 code. The lock up solnoid continuity is in spec and i have cleaned the valve assembly. The engine starts and idles perfectly but has a hesitation going up through rpm range before smoothing out and roaring to life, until the trouble code is set and it goes to safe mode. Any Ideas???
Old 01-28-2012, 12:00 AM
Pradject217's Avatar
Default Re: 2000 Accord ulev vtec, vtec malfunction code P1259
You can still drive the car. But you might have to replace the whole vtec
Solenoid.
Old 01-28-2012, 07:13 AM
dwr1977's Avatar
The plunger in the solenoid valve did have some fine scratches on the bottom portion and seemed to have more drag in the middle of its travel. Do you know if there is a difference in the solenoid assembly in the ulev and the standard vtec solenoid? Im about to go to a friends salvage yard and try to find one to try
Thanks
Old 01-28-2012, 07:20 AM
bdmlilburn's Avatar
lack of oil pressure can cause the vtec code also
Old 01-30-2012, 06:41 AM
I used my old ulev vtec solenoid. It work fine for me.
No engine light.
Old 03-02-2012, 02:34 PM
djrydercup's Avatar
I have this code on my 97 Civic too. I have a leaking VTEC solenoid. Tried replacing the o-ring but that did not fix it.
I also have some other codes (p1336, p1337, and p0325) and am wondering if any are related.
I was told that I may have to replace the Crankshaft sensor, which would cost over $400. Anyone know of anything that should be done first?
dwr1977
01-28-2012 07:04 AM
Pr0ject93hb
09-14-2007 09:50 AM
ganjasnack
06-11-2007 02:38 PM
AllMotorB
07-01-2005 08:22 PM
Quick Reply: 2000 Accord ulev vtec, vtec malfunction code P1259
