94-95 power antenna
94-95 power antenna
Does anyone know if the power antenna assembly fits the same between the sedan, coupe and wagon? i know there are some trim pieces for the wagon to make it seal right, but is the actual motor assembly and shaft the same? the wagon antenna motor has a different part number from coupe and sedan, but in the honda parts diagram, it appears the same. Even the bracket that holds the antenna in place is the same part number from the sedan and the wagon. I just want to know if i can to a junkyard and pull one from a coupe or sedan for $50 instead of shelling out $200 at the dealer. Not too many wagons at my local yards.
Re: 94-95 power antenna
The motor between a 4th and 5th ? I don't think so. (92 EX 4 dr = 39155-SM4-A04 a 94 EX 4 dr = 39150-SM4-A03)
Also a 94 Wagon is different that 94 4 dr (94 5 dr = 39150-SV5-A01 again the 94 EX 4 dr = 39150-SM4-A03).
So the the OP-are you needing the whole motor or just the mast?
