2000 Accord suspension problem
Old 08-02-2005, 10:38 AM
Me Gusta History
accordselux's Avatar
Default 2000 Accord suspension problem
I've got the 4cyl 4 door.
I had Illumina's and neuspeeds put on a few weeks ago, and just yesterday, i was getting a scraping noise coming from my drivers side front wheel.
The noise only occurs when I am turning left. It sounds like metal scraping. I have looked under and at the car and I cant see any problem.
My car was only lowered 1.8". Is the scraping noise i'm getting wheel rub? The thing is it only rubs when the wheel is turned to the left....
Thanks
Old 08-02-2005, 11:02 AM
P_Adams's Avatar
Default Re: 2000 Accord suspension problem (accordselux)
There are cases where a dust/stone shield located directly inboard from the brake rotor can be bent out of position thus causing this condition.
Not having mentioned milage, it's also possible that you may have a brake pad worn to the point that the wear sensor may be just starting to rub.
This is a place to start
P
Old 08-02-2005, 11:03 AM
Me Gusta History
Default Re: 2000 Accord suspension problem (P_Adams)
Thanks, i'll go check it out, it might be the panel (I got new ones installed) but I got new front pads only a while ago so they should still be good
bigjoncoop
03-12-2018 05:06 PM
kris1094
05-28-2013 07:05 AM
KHowe
08-02-2010 12:06 PM
thavarin
07-02-2007 02:55 PM
Cronousman
10-24-2006 08:20 PM
Quick Reply: 2000 Accord suspension problem
