2000 Accord SE Panic Alarm Problem - Honda-Tech
Old 07-12-2004, 03:20 PM   #1
nuclearfurnace's Avatar
Default 2000 Accord SE Panic Alarm Problem
I have a 2000 Accord SE and lately when I start the car the panic alarm just sounds. It cannot be shut off. THe panic button, ignition etc have all been attempted but the alarm must time out. Obviously this is unacceptable at 5a when I leave for work etc... Anyone have any ideas what can cause this? It happened a month ago, I made an appointment at the dealer and then it stopped. So they told me nothing was wrong. Now it is happening again. If there is a way I can disable the alarm that would be great too.
nuclearfurnace is offline   Reply With Quote
Old 07-17-2004, 12:18 PM   #2
EK k kay's Avatar
Default Re: 2000 Accord SE Panic Alarm Problem (nuclearfurnace)
If the ignition won't turn on and the siren is going off then try getting out of the car and inserting the key into the driver side door and turning it. My sisters 97 accord has the same thing and sometimes she either turns the ignition to turn it off or uses the method above. Hope this helps.
EK k kay is offline   Reply With Quote
Old 07-17-2004, 09:59 PM   #3
Me Gusta History
accordselux's Avatar
have you accidentaly pressed the lock button? I've noticed if you use your remote to lock the car, then start it up, your car thinks you locked the car from outside and someone's stealing you car...
accordselux is offline   Reply With Quote
civic 2001- need to reset the panic mode (does not work) Majnu Acura RSX DC5 & Honda Civic EP3 5 06-02-2014 01:52 PM
My honda civic 2004 lock and unlock works but alarm does not work. panic works thou skhan919 Audio / Security / Video 0 06-01-2014 11:10 PM
2000 accord alarm goes off intermittently - anyone have access to TSB 160601? notoriousB Honda Accord (1990 - 2002) 2 12-03-2009 01:35 PM
Alarm Question: 1998 - 1999 era Viper Alarm, keyless + panic function works, no regular arming thoug RotaryBzzzz Audio / Security / Video 3 10-21-2005 10:17 AM
1997 Honda Accord SE factory alarm problem!! Help! 97HondaSE Audio / Security / Video 0 06-18-2005 07:40 PM
Tags
2000, 2003, accord, alarm, button, disable, disabling, disconnect, honda, jumping, panic, se, setting, timeout, turning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
