identifying ac system type
Old 06-05-2012, 05:37 PM
gxz
gxz's Avatar
Default identifying ac system type
I have a 91 accord lx, and when i bought it, the ac worked good all summer, the next year it didnt work.
how do i tell if it is still r-12 or if it has been retrofitted to 134a?
Old 06-05-2012, 05:55 PM
Millertime06's Avatar
Default Re: identifying ac system type
There should be a sticker under the hood about the ac system.. it should tell there... Im thinking the car is new enough that it should require r134a..
Old 06-05-2012, 06:10 PM
nus_dogg's Avatar
Look at the A/C recharge ports. That'll tell you. R134 if I remember right has a different connector compared to R12. There's a Refrigerant kit that will tell you what you have inside your A/C system.
Old 06-05-2012, 09:14 PM
gxz
gxz's Avatar
can someone explain how to tell if its been retrofitted?
Old 06-06-2012, 04:35 AM
djkurious's Avatar
http://www.autozone.com/autozone/acc...er=142674_0_0_
Old 06-06-2012, 01:03 PM
gxz
gxz's Avatar
ok, if someone that reads this has an accord , that has been retrofitted, can you post some pics of your cars ports?
Old 06-06-2012, 07:40 PM
gxz
gxz's Avatar
ok it looks like my cars system has been retrofitted, are there only two ports ? or three? i see a fitting with a blue cap on passenger side, a fitting with a red cap on driverside, should there be one more somewhere?
Old 06-07-2012, 02:33 PM
Lost Again's Avatar
Pics.....pics....pics. R12 and R134a have the same number of ports. If the retro fit was done properly, the 134a ports have no threads on the outside....looks kind of like air tool fittings. R12 ports are threaded on the outside....kind of like a tire valve.
Old 06-07-2012, 06:20 PM
gxz
gxz's Avatar
ok, i guess the car has been retrofitted, it has "air hose type fittings" threaded onto the schrader valve type fittings.
i was asking, if there should only be the two valves in total or a third somewhere?
Old 06-08-2012, 08:51 AM
Hidenplanvew's Avatar
It hasent been retro fitted, They switched from R12 to R134 in the late 1980's. After the clean air act of 1980 something.
Old 06-08-2012, 01:51 PM
RTFM
v4lu3s's Avatar
r12 to r134 occured in 93-94 range for hondas. if it has the r134 fittings it SHOULD no longer have r12, but lots of people do lots of things....
Old 06-08-2012, 05:21 PM
gxz
gxz's Avatar
it has been retrofitted, it still has the r12 label on the underside of the hood, but it has r-134a fittings on the ports.
ive read alot about r12 systems in accords not working good when converted to r134a, but in my car it worked very well (until the next summer , when it had leaked out.) i live in the desert near las vegas, it gets hotter than hell, but the humidity is always low in the summer.
flightguy
05-11-2015 03:04 AM
LSteggyguy
07-03-2014 08:30 AM
djkurious
08-29-2012 02:17 PM
mnm99
04-23-2005 07:21 AM
cfortman
08-05-2004 09:08 PM
Quick Reply: identifying ac system type
