2000 accord Lx auto shutting off radomly
Hi everyone,
The engine has been shutting off radomly on me, and it only happens while Im stopped at a light or stop sign. It has never shut off on my while I am in motion. When it shuts off , the engine sputters a bit and then it shuts down, usually takes a few minutes to get it started back up.
things i've replaced
1. Distributor Cap &Rotor
2. Coil
3. ICM
4. Spark plug wires
5.Ignition switch
6.Fuel pump
after replacing all these things the car still does it, it doesn't do it everytime i come to a stop but it'll only do it while im stopped.
anyone have any ideas? could spark plugs be to blame?
2. Coil
3. ICM
4. Spark plug wires
5.Ignition switch
6.Fuel pump
Re: 2000 accord Lx auto shutting off radomly
I predict your problem will be fixed.
DTC's are Diagnostic Trouble Codes. The main computer runs tests at various times. These tests are labled with titles called DTC's. P0740, P0135 etc. They can help in diagnostics because they are a specific test the ECM saw a problem with.
DTC's are indicated by a Check Engine Light.
***update*** im posting this just in case someone else has this problem, it was the main relay, it very easy to get to in this model honda. I popped the new one in and it started up immediatly, and i checked the old one and it had fried soldering points on it. thanks for the help everyone
Hi i'm having a similar problem my car recently stalls while trying to start it seems like it almost catches then stalls and all the lights appear on the dash including all the door ajar and brake lights, it has also happened while running a few times always stopped never rolling like you said. Where these your symptoms, it might be the same problem?
beberle
04-15-2016 03:04 AM
