2000 Accord... check engine light and trouble codes
Old 09-20-2008, 11:39 AM
pelonesollady's Avatar
Default 2000 Accord... check engine light and trouble codes
ok my check engine light went on and I was able to get a print out of the codes of P0401 and P1491, I have a list of the possibilites but I am not a mechanic and I'm a little distressed since this is keeping me from getting my new tags because I can't get passed emissions... can anyone help?
Old 09-20-2008, 02:48 PM
FunnyVictor86's Avatar
Default Re: 2000 Accord... check engine light and trouble codes (pelonesollady)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pelonesollady &raquo;</TD></TR><TR><TD CLASS="quote">ok my check engine light went on and I was able to get a print out of the codes of P0401 and P1491, I have a list of the possibilites but I am not a mechanic and I'm a little distressed since this is keeping me from getting my new tags because I can't get passed emissions... can anyone help? </TD></TR></TABLE>
P0401: insufficient EGR system flow
P1491: EGR Valve Lift Insufficient
Old 09-21-2008, 02:14 PM
soulpwr's Avatar
Default Re: 2000 Accord... check engine light and trouble codes (FunnyVictor86)
I'm assuming its a v6? Call a dealership with your vin # and find out if the egr update was ever performed. It consists of the valve being replaced and the port being drilled to a larger diameter and cleaned out. The insufficient flow is because the port is clogged. If you wanted to do it yourself, remove the intake manifold and unclog the port right in front of the # 5 and #6 ports
executiveg
04-12-2012 01:00 AM
Prisky
05-04-2005 10:22 PM
Goodhue911
10-31-2004 07:17 AM
Quick Reply: 2000 Accord... check engine light and trouble codes
