Transmission fluid
Old 08-08-2008, 02:45 PM
Yuyodrift91's Avatar
Default Transmission fluid
I need to check transmission fluid in my Honda Accord LX 1992 and don't know how to do it. It has automatic transmission. I also need to know what transimission fluid goes in there. I am having troubles with my car, after a while of driving it stops shifting goes to lower gears and eventually stops and won't move. The only thing that worked was reverse. When I shut it down for a few minutes it would drive again normally for a while, then do the same thing again. Basically after it gets hot it does not shift. I guess it might be low on transmission fluid, or any other ideas why it is doing that? cost of repair? The car has 232,000miles on it, just 2 months ago a distributor was changed and right after that the car had a problem transmitting driving from the shop but then it was fine. Thanks
Old 08-08-2008, 03:24 PM
Mr Yamada's Avatar
Default Re: Transmission fluid (Yuyodrift91)
The transmission dip stick is located on the front of the transmission ; look straight down from the distributor area.
Check the fluid level with the engine off.
Old 08-09-2008, 04:28 AM
mongtite's Avatar
Default Re: Transmission fluid (Mr Yamada)
The dip stick will give u some indication of how dirty is seems and level you're at but that doesn't tell u if it's bad. If U haven't change it before, I would get it drain out and put new fluid in.
Old 08-09-2008, 09:58 PM
DriftMaster's Avatar
Default Re: Transmission fluid (mongtite)
I need to change mine next week. Where's the drain plug and where do I put the new oil in?
I know it's not from the dipstick area... I ain't that much of a dipsh1t... lmao
greenquark
08-05-2014 03:50 PM
charlescee
11-19-2013 08:15 PM
dns92civhatchcx
12-01-2012 08:38 AM
Thunder Cat
12-09-2005 03:39 AM
burbage
04-28-2004 04:57 PM
Quick Reply: Transmission fluid
