1999 Accord Oil in radiator but no coolant in engine. - Honda-Tech
Old 03-31-2010, 07:17 PM   #1
LS94tegra's Avatar
Default 1999 Accord Oil in radiator but no coolant in engine.
I just picked up a 1999 accord 2.3L. The guy said he originally thought it was the radiator(replaced it) still didn't fix the problem. Then went on to the head gasket, had the head resurfaced and pressure checked for cracks. Put head back on with new gasket and problem still occurs. I checked the transmission fluids. What could cause the radiator to fill with oil but no coolant exists in the engine. I'm about to just pull the motor and put another in!
LS94tegra is offline   Reply With Quote
Oil in radiator, no coolant in engine oil?? gotduhflo Honda Civic / Del Sol (1992 - 2000) 13 06-09-2015 10:07 PM
98 honda accord cannot start jerodli Honda Accord (1990 - 2002) 22 10-06-2013 05:38 PM
Accord 1999.Should I replace an engine? White_Iguana Honda Accord (1990 - 2002) 0 08-23-2012 01:35 PM
2.2 Vtec leaks coolant out of radiator and fills up overflow tank? backwards? mrbisset Honda Accord (1990 - 2002) 2 09-12-2009 09:32 PM
head gasket maybe?????????? alb_accord Honda Accord (1990 - 2002) 6 02-04-2005 07:22 AM
Tags
1990, 1999, 2002, accord, antfreeze, colant, collant, coolant, coolent, gasket, head, honda, honfa, oil, radiator, repair
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
