Help with lower timing gear.
Old 01-17-2013, 12:18 PM
worx's Avatar
Default Help with lower timing gear.
So Im going to replace the crank seal,BS seal, oil pump seal. I'm having trouble removing the timing gear of the crank the one for the main timing belt not the on for the BS. Is the a special way to remove that gear on the f22's it usually slides right out. Thanks for all the helps guys.
jminthemachine
10-27-2015 05:52 AM
boostedteg4dr
02-25-2014 08:39 PM
j4s0n1337
02-15-2012 03:07 PM
Svery
02-08-2010 01:21 AM
Quick Reply: Help with lower timing gear.
