1999 Accord 1 Fuel Injector not getting power
Old 06-17-2008, 05:22 PM
f355berlinetta's Avatar
Default 1999 Accord 1 Fuel Injector not getting power
The car runs rough at idle and sounds bad, but smooths out at higher rpms... I though it might be the distributor, so I replaced that... but it wasn't. I have replaced spark plugs, wires, and now it has a new distributor, cap and rotor, and then I figured out an injector wasn't working. So, I bought a new one and installed it, but same problem... I don't think the new injector is bad, so somehow it is not getting power. How can one injector not get power?
Old 06-18-2008, 06:52 AM
Mr Yamada's Avatar
Default Re: 1999 Accord 1 Fuel Injector not getting power (f355berlinetta)
Typically in Honda fuel injection systems the injectors all share power at all times [key on] and it is the ECU/PCM that allows the ground path for each individual injector to activate.
If the injector is not pulsing as it should there would be a cylinder misfire code stored in the computer.
Old 06-18-2008, 07:00 AM
Default Re: 1999 Accord 1 Fuel Injector not getting power (Mr Yamada)
Yes, there is the misfire code, so do I have to replace the ECU/PCM?
Old 06-18-2008, 05:13 PM
vapor40's Avatar
Borrow a noid light set, then you can check if it is getting power and pulse.
Old 06-18-2008, 05:36 PM
Default Re: 1999 Accord 1 Fuel Injector not getting power (vapor40)
I'll try that this weekend...
Old 06-26-2008, 07:46 PM
The injector is getting power when I turn the key to on position. I tried measuring the voltage while running, and the voltage was fluctuating, so I think it is pulsing. I was reading some other people's problems that are exactly like mine, and it looks like it could be a burnt valve... they never posted to say exactly what fixed it, though. So, has anyone else ever heard of that?
Old 06-26-2008, 08:56 PM
DCFIVER's Avatar
burt valve could def be the problem. Do a leak down and comp test....
davethomson
12-09-2018 04:23 AM
davethomson
Honda Civic (2001 - 2005)
12-08-2018 02:08 PM
Corksil
10-31-2011 07:52 PM
TwoKSiR
09-23-2010 06:09 PM
Acidcrakker
11-17-2007 04:11 AM
Quick Reply: 1999 Accord 1 Fuel Injector not getting power
