1998 Accord Clock Bulb Replacement - Honda-Tech
Old 06-17-2006, 09:17 AM   #1
bub0440's Avatar
Default 1998 Accord Clock Bulb Replacement
I have a 1998 accord ex. I need to replace the light bulb in the clock. Whats the easiest way to get to it. Thanks
bub0440 is offline   Reply With Quote
Old 06-17-2006, 09:41 AM   #2
yamkoo100278's Avatar
Default Re: 1998 Accord Clock Bulb Replacement (bub0440)
Head out to your local honda dealership and ask for one. I had the same problem and they gave me a replacement for 2 bucks.
yamkoo100278 is offline   Reply With Quote
Old 06-17-2006, 09:57 AM   #3
bub0440's Avatar
Default Re: 1998 Accord Clock Bulb Replacement (yamkoo100278)
How do I get to the bulb? By removing the glove box or does the clock open up some way?
Thankx
Old 06-17-2006, 03:52 PM   #4
moabiker31's Avatar
The clock and hazard light button pops out using a knife (cover the blade so it doesn't scratch your dash board). Put the knife below the clock/hazard light assembly and gently pry the clock out. Disconnect the cables to remove the assembly. Once it's out I think you have to take off the back of the clock to get to the bulb - it's been a while since I've replaced mine so I can't remember for sure.
moabiker31 is offline   Reply With Quote
Old 06-17-2006, 05:21 PM   #5
02 accord's Avatar
Default Re: 1998 Accord Clock Bulb Replacement (moabiker31)
Quote:
Nope. There is an indentation in the back cover for the bulb. You will be able to unscrew it without removing any covers.
02 accord is offline   Reply With Quote
Need a list of light bulb replacement numbers kennykenny Odyssey | Ridgeline | MDX | Pilot | RDX | HR-V 0 07-31-2015 10:57 AM
Light bulb in clock audi8t721 Honda Accord (1990 - 2002) 6 08-17-2012 08:02 PM
random bulb? thatasiankidtony Honda Accord (1990 - 2002) 0 07-24-2006 05:15 PM
01 accord digital clock bulb scul8r1990 Honda Accord (1990 - 2002) 5 06-02-2006 11:26 AM
2002 Honda accord odometer light ajmj777 Honda Accord (1990 - 2002) 1 06-23-2005 12:27 PM
Tags
1998, 2002, 98, 99, accord, backlight, bulb, clock, find, hazard, honda, light, open, replace, replacement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
