PSF leaking from end of the steering rod... pls suggest solution
Old 09-28-2018, 02:50 AM
fpracha's Avatar
Default PSF leaking from end of the steering rod... pls suggest solution
In my Honda power steering fluid is leaking from vertical steering rod's end that fits into the Control Valve attached to the steering rack/cylinder.
Old 09-28-2018, 03:05 AM
GhostAccord's Avatar
Default Re: PSF leaking from end of the steering rod... pls suggest solution
Replace the rack or see if you can find someone local who can rebuild it /install a new seal.
Probably quicker and cheaper just to replace the rack.
Old 10-02-2018, 03:47 AM
fpracha's Avatar
Thanks for the suggestion. How much would a Rack replacement cost ?
If I get the new shaft seal installed, is it more costly ?
More importantly, will the rebuild have a long life same as if a new rack is replaced ?
Vagitarian
17
06-04-2012 04:20 PM
02 accord
04-25-2010 12:45 PM
blasterman87
01-17-2010 06:13 AM
superex87
07-02-2007 10:35 AM
CivicHB93JDM
09-08-2005 09:00 AM
Quick Reply: PSF leaking from end of the steering rod... pls suggest solution
