1996 Honda Accord starter grinds every 5-10 start ups
Old 01-17-2010, 10:27 PM
minvikes's Avatar
Default 1996 Honda Accord starter grinds every 5-10 start ups
Hello everyone, I'm having a problem with my 1996 Honda Accord. I have tried searching for solutions, but to no avail
On every 5-10 starts or so I get a grinding noise as my car turns over as if the starter isn't disengaging. I've replaced the starter 4 times, and each of those times I've heard the same grinding noise with each of the starters. Again, it doesn't happen every time, and I checked the flywheel and it looked in great shape. This newest starter that I got worked great for about a week with no grinding, but then I needed a jump due to the frigidly cold weather, and since then I've had that terrible noise on occasional start-ups. Could it be due to a low battery?? I have less than half-life on it. Would a new battery solve this issue, or is it something else? Perhaps ignition switch? My car starts up right away just fine every time and I don't need to crank to get it to turn over, but it's just the grinding that is the problem. Otherwise the vehicle operates fine.
Thanks!!
Old 01-17-2010, 10:55 PM
PilotOnDubs's Avatar
Default Re: 1996 Honda Accord starter grinds every 5-10 start ups
if you had to jump your battery, chances are that its low on juice when you start it up thus causing the grinding noise at times...
recharge or replace your battery and see if that helps
AnthonyBeasley
02-22-2019 05:53 AM
rickphipps88
02-12-2018 07:23 PM
godinez90
06-09-2015 09:04 PM
1337knub
02-10-2014 06:57 AM
aznpridelivin2o3_cg5
09-26-2010 07:19 PM
Quick Reply: 1996 Honda Accord starter grinds every 5-10 start ups
