1996 Honda Accord Coolant fan control module
Old 06-05-2014, 08:04 PM
rriznyk's Avatar
Icon6 1996 Honda Accord Coolant fan control module
My 96 2.2L Honda Accord LX coolant fan does not turn on anymore once the engine shuts off. The fan used to spin regularly upon turning off the ignition until the engine cooled. We live 6 miles uphill from the ocean in Hawaii and the engine does get quite hot after this climb. Is there some way to check the coolant fan control module behind the glove box to verify if it is operational? I tried jumping ECT switch B wiring, ignition on, that controls the fan with a paperclip but nothing happened. Is it possible to jump wire the fan control module itself to get the fan to spin?
Raymond
Old 06-05-2014, 09:37 PM
holmesnmanny's Avatar
Default Re: 1996 Honda Accord Coolant fan control module
First apply direct battery power to the fan motor to be sure the fan motor itself isn't blown. Is it really hot where you live ? The fan shouldn't regularly come on after you turn off the ignition unless it's really hot out.
Old 06-07-2014, 08:05 AM
Lost Again's Avatar
Also note - if you are jumping thermo B (upper hose to engine) - DO NOT turn the ign on. You do this test with the ign off.
Thermo B only has control of "the fan" when the ign is off.
Old 06-07-2014, 12:26 PM
rriznyk's Avatar
Old 06-07-2014, 12:32 PM
rriznyk's Avatar
I know the fan motors are working as I jumped the ECT switch A and both fans turned on. Also, with AC turned on and ignition switch on, both fans spin. The coolant fan as a rule always turned on after climbing the hill back home when the engine was shut off. All of a sudden it no longer happened. The engine even overheated once and the cooling fan did not turn on even though I could hear the water boiling in the radiator.
Raymond
Old 06-07-2014, 01:01 PM
rriznyk's Avatar
I tried jumping the thermo switch B with ignition off and the fan motor did turn on. Eureka! Thanks for the tip. I think I've isolated the issue to a defective thermo switch B.
Raymond
Old 06-07-2014, 01:11 PM
longest project ever
lostforawhile's Avatar
Location: on the south side of dixie, 1986 Accord Hatch
I was going to say if you needed a module they had a half off sale at the yard today and they had one in good shape with almost everything there
Old 10-18-2015, 08:25 AM
joezmam367's Avatar
Care to share a link?
Jason Galatz
08-08-2013 03:28 PM
1989 Honda Accord
01-03-2013 06:48 PM
zrsm9
08-13-2010 08:13 AM
riztsi
12-12-2004 06:46 PM
Quick Reply: 1996 Honda Accord Coolant fan control module
