1995 v6 Accord Oil leak between oil filter base and oil pump
I have a 1995Intermittent oil leak between Oil filter base and Oil pump. Can I remove oil filter base from oil pump. If so it there a gasket between the two along with the two orings. Any suggestions on how what I am getting into?
Re: 1995 v6 Accord Oil leak between oil filter base and oil pump
http://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&catcgry1=ACCORD&catcgr y2=1995&catcgry3=4DR+EX+V-6&catcgry4=KA4AT&catcgry5=OIL+PUMP-OIL+STRAINER+%28V6%29
(#31 in the inustrated link)
They are your problem
P
to be honest there aren't such an instruction because it's just removing the oil filter then using the correct size socket to remove the oil filter housing....wouldn't recommend doing this without a proper lifting rack....you will need room to properly install the two 0-rings witch will need to be seated properly in order to seal the oil leaks effectively....it's not hard.....just really annoying....not for in-patience peoples
thanks. Thats a bit more info than I had. I cant seem to get a socket on #37 (See link below) The frame is the the way. I tried a universal joint, open box wrench and cant get the socket on.
Do I need to remove the motor mount and lower the engine?
Is there a special tool i need to use?
http://www.hondaautomotiveparts.com/...AINER+%28V6%29
They are diffucult to get to. The harmonic balancer is in the way of the bolts on 1996 Honda Accord V6. I have more money than time this time. LoL. Letting my mechanic make some money time.
holmesnmanny
12-10-2009 03:14 AM
