1995 Accord Wont start
I have a 1995 Accord lx with a 2.2l in it. Will not start. I pulled into McDonalds the other day, shut the car off, and walked inside. When I came out, the car would not start. It will crank very strong but wont start.
I have checked the following:
No fuel pressure; fuel pump does not make any noise to prime.
No spark; checked it with a spark plug grounded to the block, no go.
Main relay; I replaced it with a new one, no go
Fuses; All fuses are good
The check engine light is NOT on. Not sure where to proceed next. Any help would be greatly appreciated
Re: 1995 Accord Wont start
Same like my honda.. I use H22A.. When I start engine don't make any sound... Is it throttle body problem or stater problem? I use S90 70mm throttle body and wolbro fuel pump.. Please help...
well if ure using a walboro 255 u would deff hear it prime up so u either have an open circuit somehwhere before the fuel pump, a fuse went bad or ure pump went on you
nova1370
04-30-2012 07:07 AM
djdarksim
06-10-2005 09:52 AM
