1995 accord V6 transmission fluid - Honda-Tech
Old 01-28-2010, 11:36 AM   #1
zerovandez's Avatar
Default 1995 accord V6 transmission fluid
Hey guys, my brother has a 1995 accord v6 and he's wanting to know where to refill the transmission fluid. We found an online manual for this engine from an Acura Legend. The manual covers the drain process but doesn't cover the refill. There is a goldish bolt on top of the transmission with "ATF" printed on it but wasn't sure if this was it and I didn't want to start pouring fluid where it doesn't belong. Ideas?
zerovandez is offline   Reply With Quote
Old 01-29-2010, 07:49 AM   #2
zerovandez's Avatar
Default Re: 1995 accord V6 transmission fluid
Anyone have any experience with this at all?
Old 01-29-2010, 08:48 AM   #3
19Accord97's Avatar
Have you looked in the manual?
It shows you how to drain it and where to put the fluid.
19Accord97 is offline   Reply With Quote
Old 01-29-2010, 08:57 AM   #4
There is a fill bolt about 2 inches above the drain bolt. ATF stands for Automatic Transmission Fluid. Use Honda/Acura fluid or equivilant only, NO DEX/MERC. Fill it until fluid starts running back out of the fill hole, then cap it
1grex is offline   Reply With Quote
2004 Accord EX Transmission Fluid (ATF) Change - Is it too late? j894 Honda Accord & Crosstour (2003 - Current) 9 01-21-2017 04:15 PM
Lack of Power above 4500 rpm green95 Honda Accord (1990 - 2002) 20 05-08-2016 07:41 PM
1999 Honda Accord EX V6 Transmission problem da35apprentice Honda Accord (1990 - 2002) 12 04-12-2016 06:31 AM
Automatic Transmission fluid capacity normaspirated Tech / Misc 2 11-28-2004 07:23 PM
91 Accord Coolant leak from Transmisssion Cover plate pniddrie Honda Accord (1990 - 2002) 6 09-21-2004 09:42 AM
Tags
1995, 1996, 92, 95, accord, acura, atf, dexmerc, fluid, honda, legend, level, put, transmission, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
