Anyone running the Treadstone kit?
Is anyone running the Treadstone turbo kit on their car?
http://www.treadstoneperforman...2FH23
How was the spool on the t3/t4 as a daily driver? Did you ever have any problems with that manifold? Can you give any views or impressions?
Re: Re: (accord2nrz)
Cool, thanks for the replies guys. I did a little bit of searching and found out a little more, seems to be good pieces at a great price. The only thing that I'm questioning is the manifold.
It appears that the wastegate port is only on one runner, or is it two? I can't really tell by the picture. I'd like one where all four cylinders have access to the wastegate, I guess I can replace this piece and use the rest of the kit?
Re: Re: (Barry White Wagon)
runner 1 and 2 feed into it. It is possible to keep the ac and ps with the setup. ( I did it) but unless the exhaust is run right you will run into problems with burning up alternators. Trust me. I did it. But I am more than happy with the mani.
I spool at 2500.
I spool at 2500.
Re: Anyone running the Treadstone kit? (Barry White Wagon)
I am running the Turbonetics Kit, and I like it. The only problem I had was the Mf2 secondary injectors that came with the setup. I would suggest getting a S300, VAFC or something. And that is not all you will need bigger injectors and so to fully utilize that setup. The manifold is a little weird, on the wastegate turbonetics says not to use a gasket but i have found that you have to use a gasket there. But it is a good starter setup. The A/C line will be right over the turbo (touching) and it will melt. You will have to have a custom A/C setup to keep it. You would also be able to bend that line a tad.
Modified by Brad_and_the_acc at 8:08 AM 9/6/2008
I accept with information:The manifold is a little weird, on the wastegate turbonetics says not to use a gasket but i have found that you have to use a gasket there. But it is a good starter setup. The A/C line will be right over the turbo (touching) and it will melt.
The lines are maleable. You can bend them out of the way slightly without any issues. I don't like that manifold but for the price of the kit you can't really complain. My kit is up for sale if the car doesn't sell as a whole this weekend, but you'd have to lose a/c to use it. The good news is that it would come with a tune, downpipe, dumptube, oil pan tapped for the return line, and corresponding fueling options other than the walbro fuel pump.
That's a very interesting topic. But this field is still new to me. It will be grateful if you give me some
more information about it. Thanks in advance.
__________________
Watch Edge Of Darkness Online Free
__________________
1badda
12-16-2004 12:38 AM
22, connect, downpipe, f22, guide, hondfatech, install, installation, kit, prelude, s2000, tire, treadstone, treadstones, turbo
