1994-1997 Accord Auto Transmission questions - Honda-Tech
Old 06-17-2010, 02:05 PM   #1
SlowSOHC-T's Avatar
Default 1994-1997 Accord Auto Transmission questions
I am helping a buddy source an automatic transmission for his 1996 honda accord. My main question is are all the 1994-1997 all interchangable? I know my civics but not my accords any help would be great.
SlowSOHC-T is offline   Reply With Quote
Old 06-17-2010, 07:42 PM   #2
Default Re: 1994-1997 Accord Auto Transmission questions
According to my Transtar catalog, the 94-97 transmissions ( assuming that your buddy has a 4cyl) are MPOA,AOYA,BOYA, and it seems that there were a few engine combinations available for the 5th generation Accords,
2.2 L F22B1 I4 145 hp (108 kW)
2.2 L F22B2 I4 130 hp (97 kW)
2.2 L F22Z2 I4 150 hp (112 kW)
2.2 L H22A I4 200 hp (CF2 SIR)
There are many things to consider when swapping in different transmissions, one is the ECM, the transmission control may be different from a F22B1 than a H22A, the gear ratio may be different, since the H22A has more hp/torque, it may have a higher ratio which will make your F22B1 a gutless wonder. Shift points may be different, it is hard to say. I would keep apples to apples.
SemperFixit is offline   Reply With Quote
Old 06-17-2010, 08:14 PM   #3
SlowSOHC-T's Avatar
The motor is a FB22B2, and we plan to put a F22 trans back in. I guess I will have to see which motor it may come from.
Old 06-17-2010, 09:42 PM   #4
I cannot say for sure that there are differences...I will look further and if I find any more information for you I will post here.
Old 06-17-2010, 09:45 PM   #5
MM Gruppe B
MAD_MIKE's Avatar
Quote:
The auto boxs are all the same between the '94-'97 4cyl cars. The shifting is controlled by the transmissions controller which is inside the car. The only other difference is the Wagon has a lower final drive ratio vs the coupe and sedans.
I believe a '90-'93 transmission will also work, but the gear ratios are different from the '94-'97.
In the FAQ section there is a link on the different transmissions that can be seen F/H Series Gear Ratios
'94-'97
Sedan/Coupe..... Wagon
2.736 1............... 2.736 1
1.483 2............... 1.483 2
1.026 3............... 1.026 3
0.674 4............... 0.674 4
4.133 final.......... 4.285 final
MAD_MIKE is offline   Reply With Quote
Tanabe Sustec 1994-1997 Honda Accord Front Lower Two Point Brace jgregg For Sale 0 09-15-2016 11:52 PM
Needed: CD5 Trans Swap Parts. dglassmyer Want to Buy 1 07-28-2011 07:12 AM
1996 Accord Automatic Trans Compatibility?!? -Justin- Honda Accord (1990 - 2002) 2 02-02-2010 11:32 AM
WTB: 1994-1997 Honda Accord ASAP: Southeast! boostedDA Want to Buy 1 07-17-2007 09:34 PM
WTB: 1994-1997 Accord Ex E-brake cables coupe_hybrid Want to Buy 3 06-03-2006 02:02 AM
Tags
1994, 1997, 200, 22, 9093, 95, accord, auto, automatic, cf2, gear, h22a, honda, hp, i4, ratio, sir, transmission, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
