1993 Accord LX Overheating Issues HELP!!
Old 05-05-2013, 09:22 PM
rmason1's Avatar
Icon2 1993 Accord LX Overheating Issues HELP!!
I have replaced thermostat, radiator, and have had head gaskets, water pump and timing belt all checked by a mechanic and they said they are good... fans both work but car still wants to run hot. Once hot it cools when i let off gas then gradually climbs sitting still and when i take off again it jumps then cools. I am at a loss for what it is any takers???
Old 05-05-2013, 10:19 PM
holmesnmanny's Avatar
Default Re: 1993 Accord LX Overheating Issues HELP!!
Idle the car with the radiator cap off and rev it to see if coolant bubbles shoot out of the cap.
Old 05-06-2013, 06:20 AM
rmason1's Avatar
Is that to check for air in the system? If so the mechanic has gone through the process to get the air out already
Old 05-06-2013, 10:38 PM
No, you're checking the head gasket for coolant leaks.
But if you don't want ideas, you shouldn't be coming here for help. Just have your mechanic find the problem.
Old 05-13-2013, 03:50 AM
rmason1's Avatar
If you want to give ideas maybe you should read in the original post the head gaskets have already been checked...
Old 05-13-2013, 03:52 AM
If he was a legitimate mechanic he would have fixed the issue by now...
Old 05-13-2013, 09:53 AM
Dirt McHondy's Avatar
C'mon... with the bickering...
Did you try the rad cap thing, though?!
Bilster
11-08-2014 06:58 AM
bobbyisda1
04-05-2009 10:31 PM
discman
01-18-2008 07:56 AM
superstock2
15
09-01-2006 09:44 AM
silinteg90
05-09-2005 07:56 PM
Quick Reply: 1993 Accord LX Overheating Issues HELP!!
