1992 Accord sputtering and backfiring out of throttle body... FRUSTRATED!!
Old 01-11-2013, 07:09 PM
Tampacb7813's Avatar
Default 1992 Accord sputtering and backfiring out of throttle body... FRUSTRATED!!
So this car has been hell trying to figure what is wrong with it!! I thought it was a fuel delivery problem........ I have replaced the fuel filter.... fuel pump. And still has not changed. So I replaced the coil, cap, rotor, wires and plugs still has not changed. Changed map sensor, checked main relay..... I have spent $600 on this car all ready!! It takes awhile to start.... and once it starts it fires on all 4 cylinders until you give it throttle and it starts sputtering like crazy, and starts backfiring out of the intake.... Please any help. Im so frustrated and stressed......
Old 01-11-2013, 07:10 PM
Default Re: 1992 Accord sputtering and backfiring out of throttle body... FRUSTRATED!!
BTW I am getting a CEL code # 41 which is a bad oxygen sensor.....
Old 01-11-2013, 07:40 PM
themiz816's Avatar
have you replaced the o2 sensors then?
Posted from Honda-tech.com App for Android
Old 01-11-2013, 07:54 PM
jdowen2's Avatar
Check your timing. Belt may have jumped a tooth.
Old 01-11-2013, 08:28 PM
yes
Old 01-11-2013, 08:29 PM
I dont think it is the timing belt because there are times when it runs perfect... and it is not sputtering or backfiring. It will run fine for about 2 minutes then start acting up. Could the ignition module be the culprit?
Old 01-12-2013, 03:44 AM
GhostAccord's Avatar
Backfiring out the intake is usually a condition relative to a timing or ignition issue. That or a bent or burnt intake valve.
Where it takes a long time to start. Have you replaced the battery or had it tested?
Have you done a compression test or leak down test on the engine?
What did the old spark plugs look like and what do the new ones look line now? The condition of the spark plugs can tell you a lot about the combustion conditions in the engine.
Old 01-12-2013, 05:46 PM
The number 3 and 4 cylinder plugs were very black.... and number 1 and 2 plugs were normal
Old 01-12-2013, 05:48 PM
Havent done a compression test..... Took the cam gear cover off and put the bottom end in time and the top end was off a little less then a tooth
Old 02-04-2020, 06:43 PM
Rosetta Mathis's Avatar
Im doing this same job thanks for the suggestions will check and see what works. Will update on results soon.
netfreak
08-29-2018 04:57 PM
wasp9166
24
09-26-2012 01:38 PM
Rogue
12-25-2011 09:38 AM
x91crxsix
05-20-2008 09:04 AM
boostedEBP
01-28-2008 07:29 PM
Quick Reply: 1992 Accord sputtering and backfiring out of throttle body... FRUSTRATED!!
