1991 Honda Accord EX, Sport Light Stays On/ Transmission Problem - Page 2 - Honda-Tech
Old 01-06-2011, 05:44 AM   #26
Default Re: 1991 Honda Accord EX, Sport Light Stays On/ Transmission Problem
Nice. I must have missed the posts on the DIY fix.
I suggest you change your email addy to something like blablabla -thisisthat@symbol- gmail.com .
You know? For spam purposes.
WebDawg is offline   Reply With Quote
Old 06-05-2011, 01:11 PM   #27
Thanks for the post guys, I followed the instructions and changed the capacitors as advised. However, now when I go to start the car it keeps cranking and isn't turning over. The cars in neatural because the neutral safety switch is bad. That's next in line to be replaced. Any ideas on why it won't start? Not sure where these blue connectors are to get the trouble code?
Dago84 is offline   Reply With Quote
Old 06-08-2011, 02:19 AM   #28
Bump anyone?
Old 06-19-2011, 07:01 PM   #29
Ok so I have same problem sport light stays on. Jump the blue connector and it does nothing, light don't blink at all. Replaced the vss, shift selonoid, and had TCU rebuilt. Light is still on and car won't shift into overdrive. Any ideas?
tommyNhisCivic is offline   Reply With Quote
Old 06-21-2011, 09:28 AM   #30
Usually the TCU's give a lot of problems with these cars. I'm not a big fan of resistance testing but check the resistance in the shift solenoids. Specifications are 12-24 ohms for each solenoid.Drive the car for about 15 minutes then check the solenoid resistance. Sometimes the shift solenoid windings short and burn the TCU. I am a Honda/Acura service technician in North Carolina and I repair Transmission computers for 1990-1993 Accords. For $90.00 plus around $5.00 shipping I can repair yours and get it back to you with quick turn around time. Let me know if I can help.
justinsbg is offline   Reply With Quote
Old 08-09-2011, 09:03 PM   #31
Recently bought this 91 Accord (automatic), ran fine on 1st day, after that I got the flashing "s" and noticed that after stopping at a light it starts hesitating to get past 10 mph, so what I've been doing (I think its bad) is putting it in the 1 gear to get it to accelerate then I shift to 2,d3 then d4 when I'm going like over 40mph (runs fine going even 80mph). That seems to work fine, but that S is super annoying. Now I have another problem, the dash brake light is almost always on even though I don't have the hand (emergency) brake on. Oh, one more thing the door ajar light is on, and the door is closed perfectly fine. I bought this car thinking that yeah it was cheap and pretty nice, and I thought it would be gas efficient, but no not so much, I work about 5 miles away plus I have to do alot of drop offs/ pick ups (kids from school) and I'm using like $10 a day - which is pretty much what I was using with my 03 Expedition. I'm looking at everyone talk about TCU, VSS, I'm confused.... Please help, I don't have a lot of money....
girlhasa91honda is offline   Reply With Quote
Old 08-12-2011, 04:19 AM   #32
The TCU or Transmission Control Unit is the most likely cause for your shifting problems. Check your brake master cylinder under the hood for the brake fluid level, if it's low it will cause the brake light to illuminate. The most likely cause for the door ajar light is the door switch which is a little push button switch on the door jam. When door closes it pushes that switch in which then is supposed to turn the light off. If you need help with your TCU let me know. I work in NC and repair TCU's. Be aware of buying used TCU's, you may end up with the same problem.
Old 08-16-2011, 01:10 AM   #33
Default Re: 1991 Honda Accord EX, Sport Light Stays On/ Transmission Problem (trwpaper)
Quote:
Originally Posted by brownje000 View Post
Hello Im having the same problem with my 91 lx honda accord I have 254,000 miles on it except my speedometor sometimes dosen't work. I took it to the shop and the person said its one the two sensors Im just going to replace both because im pretty sure the other sensor that is good now will go out later.
Hi there, I fix a couple of problem like this, just go to pick n pull and buy a speed sensor, it will solved your problem... good luck..
hobbytech is offline   Reply With Quote
Old 10-16-2011, 02:28 PM   #34
I've got a 90 and the flashing s too. I just put in a VSS from pick n pull. Still flashing. Just bought a new one off ebay fro $20. I'll let you know.
fringledingle is offline   Reply With Quote
Old 10-17-2011, 02:08 AM   #35
What sensor they talking about?.... What I experienced to this kind of problem is the vehicle speed sensor (vss).... Go to pick n full cheaper... Good luck...
Old 10-17-2011, 10:42 AM   #36
Quote:
Reference my posts above about problematic TCU's (Transmission Control Unit), and shift solenoids It's a very common problem on 1990-1993 Accord automatic transmissions. I repair them in NC where I work as an automotive/electronics repair technician.
Old 10-17-2011, 04:57 PM   #37
Quote:
Unfortunately it's my daily driver. I can't afford to send the TCU off for who knows how long. Can I rip one out at pick n pull? will it work?
Old 10-17-2011, 11:05 PM   #38
egsleepercivic's Avatar
had this problem on a 93 ex, I was able to open the tcu to find the burnt parts before replacing got a new one on ebay for 80 shipped
this site is worth a read for anyone having this problem with 90-93
http://techauto.awardspace.com/transmission.html
egsleepercivic is offline   Reply With Quote
Old 10-19-2011, 05:51 PM   #39
thx..will try the reset as I don't really want to replace the tcu.
Old 10-29-2011, 02:17 PM   #40
new speed sensor restored my speedometer however the light still mocks me and I have no cruise control. I'm stumpped
Old 11-27-2011, 04:20 PM   #41
Quote:
Originally Posted by Mr Yamada View Post
It is common that when the S light comes on the Trans Control Unit will store a fault code.
You will be able to retrieve the fault code by jumpering the blue 2 pin service connector then turn on the key and watch the S light for a flash code.
I would not recommend that you have the transmission taken apart, as the usual cause of an 'S' light is an electrical problem, not an internal failure of the transmission.
New member here. Have a 50,000 mile 1991 Accord driven by mother in law....S (sport light) stays on and shifting is very poor, no overdrive seems to work. Checked codes by jumpering blue connector-no codes, S light still on steady and CEL also comes on steady.
Since no codes to check, what is the next clear step? The TCU is original, and this car was purchased new, does not seem TCU is within the "improved" list of TCU retrofits....
So, where do I begin?
cardmarc is offline   Reply With Quote
Old 11-29-2011, 07:12 PM   #42
As a follow up to this, I took the TCU box out (what a pain in the kister), opened up the box and looked for the burned resistor and leaking cap....found them both, but I have a DIFFERENT leaking Nichocon capacitor than the one written up on the nice fix it website....at here..... http://people.consolidated.net/etrid...ordtcufix.html
The one I had leaking was 220uf 35 volt cap. Ordered 5 new caps and the one resistor for $2.39 from DigiKey. Postage costs more, another 2.50. Since I can solder ok I figure this is a $10 fix if it works. Will post later when I get the parts as to the results! Sounds promising.
Old 11-29-2011, 09:06 PM   #43
here is a pic of the 93 ex tcu that I replaced, burnt stuff is circled
Old 12-03-2011, 11:45 AM   #44
Hello, yes, that resistor (marked R41) was blown on mine, too. As well the capacitor just to the top of this resistor was blow out at the bottom. It is marked C28. The other capacitor that the fellow wrote about being blown in his TCU unit is marked C32. So I replaced all the above 3 components, plus capacitor C33 because it was close. I also bought two extra caps of the same sort I saw on the board but did not replace them. Cost a total of $5.00 with shipping!
I am happy to report that the fix was successful and that the Sport light is now out, and that the car shifts fine. Hoooray for all of us.
Now to fix my noisy left turning wheel bearing (or CV joint........?) How do I tell which is bad?
Old 02-19-2012, 11:28 AM   #45
Icon7 Re: 1991 Honda Accord EX, Sport Light Stays On/ Transmission Problem
Last week I sold my 1991 Honda Accord. It had 212,000 miles. I hope it goes another 200,000.
That generation of Accords are awesome; well-built, durable, ride smooth, stone axe reliable. I would have kept that Accord, but I ran across a steal of a deal on a 2003 Honda Pilot 4x4 with 144,000 miles.
Everyone please work to keep these Hondas on the road FOREVER!
John Bennett is offline   Reply With Quote
Old 02-24-2012, 02:32 AM   #46
dida4g's Avatar
Great thread this, I can look for an auto Accord now.
dida4g is offline   Reply With Quote
Old 02-27-2012, 07:41 AM   #47
I've just had a successful brain transplant (switched the TCU). No more flashing lights, shifting awesome and it only took 20 minutes...and a couple swears. Well worth it.
Old 11-02-2014, 07:18 PM   #48
I I have a 1991 Honda accord AT control unit on the motherboard what size capacitor goes on C28 and C33
i can replace them they are gone can you help me with the info Thanks!!!
myhighway66 is offline   Reply With Quote
Old 11-03-2014, 06:45 AM   #49
I do not have the car anymore. Sorry :/
Old 02-11-2015, 11:56 AM   #50
Hello Sir, i have the same car and have a similar problem. Please how do i locate and jumper the 2 blue pin connector to get the code, and what do i do with the code to resolve the issue. You can also reach me at dimu4ever@yahoo.com
I live in Nigeria. Thanks
dimu4ever is offline   Reply With Quote
1991 Honda Accord auto transmission stuck in sports mode not shifting dcsalling Honda Accord (1990 - 2002) 26 08-31-2016 12:53 PM
1991 Honda Accord "S" light issue Ripacord Honda Accord (1990 - 2002) 7 06-09-2016 08:54 AM
91 Accord TCU questions 91Accordkid Honda Accord (1990 - 2002) 0 06-02-2015 05:32 PM
1991 Honda Accord LX Transmission maybe TCU alockhart10 Honda Accord (1990 - 2002) 2 03-31-2015 05:18 PM
Prelude TCU Qustions, 2 Transmissions blown TECH HELP NEEDED whitelite420 Honda Prelude 1 11-24-2006 03:19 PM
Tags
1990, 1991, 91, accord, fix, gear, honda, light, mode, problems, road, sport, sports, stay, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
