1991 honda accord ex cooling fan not turning on
Old 06-30-2013, 11:24 PM
junior91hondaac's Avatar
Default 1991 honda accord ex cooling fan not turning on
My cooling fan wont come on 1991 honda accord ex
Old 07-01-2013, 02:08 AM
bairdandrew77's Avatar
Default Re: 1991 honda accord ex cooling fan not turning on
cooling system bled properly?
Old 07-03-2013, 02:19 PM
Lost Again's Avatar
Which one? Both or just one side?
Old 07-09-2013, 02:47 PM
The driver side fan dont turn on..the passenger side fan only comes on when i drive the car for a while and i get off the car it stays on for a few minutes then it turns of..
Old 07-09-2013, 10:20 PM
I thought the driver side fan is for the ac? turn on the ac and see if it turns on. Also, would it work if you jump it?
Old 07-10-2013, 04:12 AM
Merkle's Avatar
The fan on the left (driver's side) is for the A/C it won't come on unless the A/c is on.
Check the relays and fuses.
Old 07-11-2013, 08:10 AM
Lost Again's Avatar
Originally Posted by Merkle
The fan on the left (driver's side) is for the A/C it won't come on unless the A/c is on.Check the relays and fuses.
Not correct. Thermo A controls BOTH fans. Meaning if the car is on and Thermo A gets to temp (~199 F) BOTH fans should run.
Old 07-12-2013, 04:49 PM
Lou808's Avatar
Hi, I have a 92 accord. What and where is Thermo A? How do I check if its functioning properly.
Sorry to interject.
Tnx Lou
Old 07-12-2013, 11:57 PM
Thanks for replying its much appreaciated..well i try everything and my cooling fan dont turn on..can it be the timer box the one under the steering colum?coul that be why my cooling fan wont come on when it gets hot? How about that sensor under neeth the distrubiator,its mounted tp the block? What does that sensor is for? Also if the sensor that is mounted to the top radiator hose dont work could that be the cause of why my cooling fan (driver side) isnt turning on when the engine gets hot? To answer the question both fans do come on when i jump them.that how i have them right now ...
Old 07-13-2013, 03:39 AM
holmesnmanny's Avatar
You have two fans on your car. They both need to run at the same time while the car is on. This time keep an eye on exactly which ones run and which ones don't.
When you figure that out, report back in detail so you can get some real advice.
Old 07-14-2013, 03:51 AM
Lost Again's Avatar
Sorry to interject.
Tnx Lou
Thermo A is on the t-stat housing where the lower hose connects to the engine.....green two wire connector. If you are testing - remove the connector and use something (paperclip, piece of wire) to jump the two wires together. Turn the key to "on"/pos II and BOTH fans should run.
Old 07-14-2013, 04:33 PM
hondatech912's Avatar
You do have a fan timing unit behind the glove box. If everything else checks out pull that timer unit out and open it up to see if the circuit board is burnt.
gustavobt
10-17-2018 07:50 AM
sunshine032567
02-01-2016 03:12 PM
junior91hondaac
10-27-2014 12:03 PM
H0nda_Crazy
05-05-2013 10:52 PM
MJMAccord
09-30-2010 11:31 AM
Quick Reply: 1991 honda accord ex cooling fan not turning on
