1991 Accord EX, seat belt Control unit ? - Honda-Tech
Old 07-05-2007, 08:25 AM   #1
resqfog's Avatar
Default 1991 Accord EX, seat belt Control unit ?
New to Site, But from what I have viewed so far, I am impressed at the knowledge base. I have been given the run around by my local dealer with an issue regarding the front drivers side seat belt, I was told that the seat belt control unit needed to be replaced after I already replaced the rail assembly, lifetime warranty apparently does not apply to the control unit. how do i disable or replace this unit? the beeping is making me go crazy.
resqfog is offline   Reply With Quote
Old 07-12-2007, 08:10 AM   #2
2004NSX's Avatar
Default Re: 1991 Accord EX, seat belt Control unit ? (resqfog)
My 91 was/is doing the same thing. I opened up the unit and pulled out "noise maker". I want to find a new control unit but can find any part #'s. Do you have any ideas? My belt wont retract for egress.
2004NSX is offline   Reply With Quote
Old 07-13-2007, 06:34 AM   #3
resqfog's Avatar
Default Re: 1991 Accord EX, seat belt Control unit ? (2004NSX)
I called Honda America and found out that it is covered under lifetime warranty, no matter how many miles or if you are the original owner. so take it to the dealer. One word of advice my local dealer has had no idea and they replaced the rail assembly even though I told them it was the control unit, my car has been at the dealer for 3 weeks now because they messed up my dash system(speedometer,fuel gauge), the number listed is 81831-sm2-A03 good luck.
Old 07-13-2007, 06:12 PM   #4
2004NSX's Avatar
You ROCK! Thanks I'll do that ASAP..
Good luck on getting you dash stuff fixed. You will..
I just found a used module so that Honda won't see I pulled the little noise maker out.
Electrical guru needed. Current draw issue from Automatic seat belt control unit? 91akira Acura Integra 22 10-12-2016 04:14 PM
I own a 2009 civic lx. captainstoob Honda Civic (2006 - 2015) 1 07-09-2016 05:48 AM
SRS code 09-03 76 camaro car Honda Accord (1990 - 2002) 2 07-03-2016 03:55 PM
Seat belt problem f22b2 Acura Integra 2 05-11-2016 07:41 AM
SRS repair questions. [I need help] Daleford Honda Civic (2001 - 2005) 18 06-23-2007 08:57 AM
Tags
1991, 81831sm2a03, 91, accord, belt, control, cover, good, honda, luck, module, seat, seatbelt, unit, warranty
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
