1991 Accord Cooling Fan Wiring Diagrams
I need a wiring diagram for the cooling fan system... Mine turns on all by itself even after the car has been sitting over nite and sometimes runs all nite... Unpluging the cooling fan sensor will not turn it off ... Unpluging the Fan relay works... Its a LXR with AIR
Re: 1991 Accord Cooling Fan Wiring Diagrams (HarleyV)
http://members.troublecodes.ne...h.jpg
The sensor that usually goes bad is the sensor in the top rad hose at the head outlet. Be surethe coolant is full and the block is burped thru the 12mm bleed screw at the T-stat housing.
i got the same problem and i unplugged the fan relay and i'm now driving the car w/o the fan relay. Would that cause the
car to be overheated overtime?
Modified by hondasucker at 10:09 AM 7/7/2004
brimac
08-25-2014 05:09 PM
